08-27-2021, 15:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: CUBA Age: 32
Member: 2108610 Status: Offline Thanks Meter: 379 | Multiples error M2101K7BNY Redmi Note 10S, Not Erase FRP Operation: Erase FRP Software version: 2.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM91 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA5FD5C24, 0x90BA9F07, 0xF713232B, 0x88834D73 Get Chip ID... [MT6785] Get SOC ID... [FA947C9BAEFB0AC10BB05C1DB7A8821528079DBD717EFFEC81 C5F83F8E2D48E1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... error(8), skip Format "frp" partition... error(1) Selected model: Xiaomi M2101K7BNY (Redmi Note 10S) Operation: Unlock bootloader Software version: 2.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM91 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA5FD5C24, 0x90BA9F07, 0xF713232B, 0x88834D73 Get Chip ID... [MT6785] Get SOC ID... [FA947C9BAEFB0AC10BB05C1DB7A8821528079DBD717EFFEC81 C5F83F8E2D48E1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... error(2) |
