07-08-2021, 04:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: australia
Member: 721542 Status: Offline Thanks Meter: 56 | Nokia 2.3 network unlock still ask for code [Answered] Selected model: Nokia TA-1211 (Nokia 2.3) Operation: Unlock network Software version: 2.0 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x2F770C8B, 0xE13E3233, 0x59FB536C, 0xCED8274A Get Chip ID... [MT6761] Get SOC ID... [CD56A8CA1F61E96A392992D48E6A6239D8A98D7EC597D9417D 8464CCE87CC3CF] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xF40122426977696E2010000000CCA7AB Load EMI config from database [DB VER: 146 DB DATE: 06-30-2021] OK [1] Trying EMI [17FE6D1D] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0xF40122426977696E2010000000CCA7AB EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0735000000 (28.83Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read lock info... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! |
07-08-2021, 12:58 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
We will try to fix in next update in 1-2days. | |
The Following User Says Thank You to blang For This Useful Post: |
09-04-2021, 10:31 | #3 (permalink) | ||
Major Poster Join Date: Jul 2010 Location: Richmond
Member: 1351559 Status: Offline Thanks Meter: 14 | Quote:
04-02-2022, 10:23 | #5 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: ukraine lviv
Member: 624189 Status: Offline Thanks Meter: 4 | Quote:
read codes show ^?^ sign, first code doesnt correct | |
04-02-2022, 10:56 | #6 (permalink) |
Member: 624189 Status: Offline Thanks Meter: 4 | here is partitions backup https://mega.nz/file/Y1pTSITC#pyViOn...DlpuijzJoTcNBU |
04-02-2022, 13:42 | #7 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 5,065 | Quote:
The Following User Says Thank You to Z3X For This Useful Post: |
05-14-2022, 15:43 | #8 (permalink) |
Crazy Poster Join Date: Mar 2015 Location: iran
Member: 2365404 Status: Offline Thanks Meter: 9 | hi pandora team i have problem unlocking this phone pls help Selected model: Nokia TA-1211 (Nokia 2.3) Operation: Read Codes Software version: 3.4 Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Tue Jul 14 18:28:22 CST 2020 Display ID : 00WW_2_260_SP01 Security Patch : 2020-07-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00WW_2_26A Read security partition from phone... OK Read security files... OK Read lock info... OK N Code : ???????? NS Code : ???????? SP Code : ??005555 C Code : ????0099 SIM Code : ???????? NS_SP Code: ???????? SIM_C Code: ???????? Read Codes done! And error Unlock Network: Selected model: Nokia TA-1211 (Nokia 2.3) Operation: Unlock network Software version: 3.4 Read partitions info from phone... OK Check A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Tue Jul 14 18:28:22 CST 2020 Display ID : 00WW_2_260_SP01 Security Patch : 2020-07-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00WW_2_26A Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Write lock info... error(ERR_COMP) |
05-14-2022, 18:46 | #10 (permalink) |
Member: 2365404 Status: Offline Thanks Meter: 9 | Selected model: Nokia TA-1211 (Nokia 2.3) Operation: Unlock network Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1D3EFC7A, 0x1E3E2D93, 0x340C95A5, 0x355E8174 Get Chip ID... [MT6761] Get SOC ID... [02D99C2F43D993FF6A2DEF194103D3806E267291E8E426EF39 D94024A8E88211] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x7001005441323833322031F445AFB6F1 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x7001005441323833322031F445AFB6F1 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x074A000000 (29.16Gb) RAM INFO: INT_SRAM: 0x000003A500 (233.25Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Tue Jul 14 18:28:22 CST 2020 Display ID : 00WW_2_260_SP01 Security Patch : 2020-07-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00WW_2_26A Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Write lock info... error(ERR_COMP) |
05-15-2022, 10:59 | #11 (permalink) |
Member: 2365404 Status: Offline Thanks Meter: 9 | bro . i downgrade from 10 to 9 Do Unlock netwrok operation and say DONE But not unlocked: Code: Selected model: Nokia TA-1211 (Nokia 2.3) Operation: Unlock network Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1D3EFC7A, 0x1E3E2D93, 0x340C95A5, 0x355E8174 Get Chip ID... [MT6761] Get SOC ID... [02D99C2F43D993FF6A2DEF194103D3806E267291E8E426EF39D94024A8E88211] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x7001005441323833322031F445AFB6F1 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x7001005441323833322031F445AFB6F1 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x074A000000 (29.16Gb) RAM INFO: INT_SRAM: 0x000003A500 (233.25Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Product Board : MT6761 Board Platform : MT6761 Build ID : PPR1.180610.011 Build Date : Thu Feb 27 02:24:32 CST 2020 Display ID : 00WW_1_400 Security Patch : 2020-03-05 Version SDK : 28 Version Release : 9 Version Codename : REL Firmware Version : 00WW_1_400 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! |
05-15-2022, 19:09 | #13 (permalink) |
Member: 2365404 Status: Offline Thanks Meter: 9 | bro read code only show ??????? Code: Selected model: Nokia TA-1211 (Nokia 2.3) Operation: Read Codes Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1D3EFC7A, 0x1E3E2D93, 0x340C95A5, 0x355E8174 Get Chip ID... [MT6761] Get SOC ID... [02D99C2F43D993FF6A2DEF194103D3806E267291E8E426EF39D94024A8E88211] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x7001005441323833322031F445AFB6F1 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x7001005441323833322031F445AFB6F1 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x074A000000 (29.16Gb) RAM INFO: INT_SRAM: 0x000003A500 (233.25Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Product Board : MT6761 Board Platform : MT6761 Build ID : PPR1.180610.011 Build Date : Thu Feb 27 02:24:32 CST 2020 Display ID : 00WW_1_400 Security Patch : 2020-03-05 Version SDK : 28 Version Release : 9 Version Codename : REL Firmware Version : 00WW_1_400 Read security partition from phone... OK Read security files... OK Read lock info... OK N Code : ???????? NS Code : ???????? SP Code : ??005555 C Code : ????0099 SIM Code : ???????? NS_SP Code: ???????? SIM_C Code: ???????? Read Codes done! |
05-16-2022, 06:55 | #15 (permalink) |
Member: 2365404 Status: Offline Thanks Meter: 9 | |
