Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2017
Member: 2784298 Status: Offline Thanks Meter: 11 | nokia TA-1221 unlock failed Operation: Unlock network Software version: 3.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM79 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xD16EE2C9, 0x3D2AE7FC, 0xFA5C21B9, 0xADCC63B0 Get Chip ID... [MT6761] Get SOC ID... [EAAB89FE86E9E1594A0A8F8009EDEC3FAF3EA8D41E70246C51 C4403F41B6C382] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x700100474D41474441702959D19987B5 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x700100474D41474441702959D19987B5 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A6800000 (14.60Gb) RAM INFO: INT_SRAM: 0x000003A500 (233.25Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2 V Tella Product Name : Armstrong_VZW Product Device : armstrong Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Fri Mar 12 19:06:09 IST 2021 Display ID : 00VZW_0_640 Security Patch : 2021-03-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00VZW_0_640 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Unlock... OK [DF1, DF2, GB1, GB2] Write lock info... error(ERR_COMP) |
![]() | #3 (permalink) |
Member: 2784298 Status: Offline Thanks Meter: 11 | Selected model: Nokia TA-1221 (Nokia 2V) Operation: Read Codes Software version: 3.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM14 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6A84DEF2, 0xB6F5A6B2, 0x6F3D9545, 0x106B0C54 Get Chip ID... [MT6761] Get SOC ID... [4A7921D57F51DC4FB37C07D8CFAD5717BA2625E4CAD830C1AD 94E45C7779017A] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x700100474D41474441700B688D682753 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x700100474D41474441700B688D682753 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A6800000 (14.60Gb) RAM INFO: INT_SRAM: 0x000003A500 (233.25Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2 V Tella Product Name : Armstrong_VZW Product Device : armstrong Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Thu Aug 13 18:08:38 IST 2020 Display ID : 00VZW_0_340 Security Patch : 2020-07-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00VZW_0_340 Read security partition from phone... OK Read security files... OK Read lock info... OK N Code : 12345678 NS Code : 56781234 SP Code : 11112222 C Code : 33334444 SIM Code : 55556666 NS_SP Code: 77778888 SIM_C Code: 99990000 Read Codes done! |
