05-09-2022, 13:10 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: chittorgarh (Raj.) INDIA
Member: 363265 Status: Offline Sonork: 100.1648064 Thanks Meter: 65 | oneplus nord 2 imei null [Answered] Selected model: Mediatek Mediatek Operation: Repair META Software version: 3.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Get sec config... OK [000000E0] Active sec flags: [] Switch to META mode... OK MetaCore version [10.2124.0.3] Wait port for connecting... OK Connecting to AP COM(16)... OK modem_number = 1, modem_id = 1 md service = 2, ch type = 2 current modem type = Not Defined modem img type[0] = 14 Connecting to META... OK BB_CHIP : MT6893 SW_TIME : 2000.00.00 DSP_FW_VER : 1.0 SW_VER : OPPO_K6893V1_64_HW HW_VER : Unknown MELODY_VER : NLWCG_CUSTOM NVSecOn ... OFF Load DB From target... OK NVRAM init ... OK CURRENT IMEI: IMEI1 = EMPTY IMEI2 = EMPTY Set IMEI 1 to 865185054308179... OK verify IMEI 1... IMEI 1 = EMPTY |
05-09-2022, 13:14 | #2 (permalink) |
Member: 363265 Status: Offline Sonork: 100.1648064 Thanks Meter: 65 | Selected model: Mediatek Mediatek Operation: Repair Software version: 3.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE9C77D58, 0x8AB9D9BC, 0x20DD7873, 0x56DB2D3E Get Chip ID... [MT6893] Get SOC ID... [2FC825C911BB41DF593F8C87CD28CFEFEAA3E73DDC8FADB75E 633110AC0F052E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUDG4UHDC-B0E1 (0600) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUDG4UHDC-B0E1 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oplus6893 Board Platform : MT6893 Build ID : RP1A.200720.011 Build Date : Wed Dec 29 22:35:09 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-12-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1640787928920 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 2810;:=8??473?7 IMEI 2: 187392=:>8645:> Repairing IMEI... IMEI 1: 865185054308179 IMEI 2: 865185054308161 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! show done but nothing changed .... i wipe nd format also after repair |
05-17-2022, 06:15 | #8 (permalink) | |
Member: 363265 Status: Offline Sonork: 100.1648064 Thanks Meter: 65 | Quote:
sorry for late respond coz of madical emergancy.... here is log with 3.4 Selected model: Mediatek Mediatek Operation: Repair META Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Get sec config... OK [000000E0] Active sec flags: [] Switch to META mode... OK MetaCore version [10.2124.0.3] Wait port for connecting... OK Connecting to AP COM(16)... OK modem_number = 1, modem_id = 1 md service = 2, ch type = 2 current modem type = Not Defined modem img type[0] = 14 Connecting to META... OK BB_CHIP : MT6893 SW_TIME : 2000.00.00 DSP_FW_VER : 1.0 SW_VER : OPPO_K6893V1_64_HW HW_VER : Unknown MELODY_VER : NLWCG_CUSTOM NVSecOn ... OFF Load DB From target... OK NVRAM init ... OK CURRENT IMEI: IMEI1 = EMPTY IMEI2 = EMPTY Set IMEI 1 to 865185054308179... OK verify IMEI 1... IMEI 1 = EMPTY | |
05-17-2022, 06:18 | #9 (permalink) |
Member: 363265 Status: Offline Sonork: 100.1648064 Thanks Meter: 65 | in flash mode show success but still null .... here is log Selected model: Mediatek Mediatek Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE9C77D58, 0x8AB9D9BC, 0x20DD7873, 0x56DB2D3E Get Chip ID... [MT6893] Get SOC ID... [2FC825C911BB41DF593F8C87CD28CFEFEAA3E73DDC8FADB75E 633110AC0F052E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUDG4UHDC-B0E1 (0600) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUDG4UHDC-B0E1 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oplus6893 Board Platform : MT6893 Build ID : RP1A.200720.011 Build Date : Wed Dec 29 22:35:09 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-12-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1640787928920 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 2810;:=8??473?7 IMEI 2: >768>1331439819 Repairing IMEI... IMEI 1: 865185054308179 IMEI 2: 865185054308161 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Repair Security done! |
04-08-2023, 09:00 | #13 (permalink) |
Freak Poster Join Date: Sep 2013 Location: VELLORE
Member: 2029741 Status: Offline Thanks Meter: 61 | Selected model: Mediatek Mediatek Operation: Read Flash Info Software version: 4.10 Work ID: 1438765 Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM31 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM31 [BROM] Open port... error how to fix? |
04-08-2023, 09:48 | #14 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Quote:
