03-12-2022, 15:14 | #3 (permalink) |
Crazy Poster Join Date: Jan 2017
Member: 2667931 Status: Offline Thanks Meter: 8 | Selected model: OPPO CPH2179 (Oppo A15s) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM0 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x33D34A41, 0xB91D9EAC, 0xCBCBDD49, 0xACDFE73A Get Chip ID... [MT6765] Get SOC ID... [FE709E309C768C75E6B78071CCFC230D0045950D2A6DA286AA AA7DC314353076] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A39523810115C999138B5 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A39523810115C999138B5 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6765 Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Fri Nov 26 23:26:27 CST 2021 Display ID : QP1A.190711.020 release-keys Security Patch : 2021-12-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 356152065599630 IMEI 2: 000000000000000 Write IMEI [NVDATA]... OK Load partiton for patching... OK Patching CERT... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. here is log sir I have 2 pcs device same problem after repair imei |
03-12-2022, 16:11 | #8 (permalink) |
Freak Poster Join Date: Feb 2017
Member: 2682141 Status: Offline Thanks Meter: 48 | Dear Read My Answer Again The Firmware Must be Appropriate and Tested. Many Firmwares of the same model are not good and doesnt not fix soft brick phones. Restore back up and flash the phone with Appropraite firmware will do the job. |
03-13-2022, 04:33 | #11 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: CUBA Age: 32
Member: 2108610 Status: Offline Thanks Meter: 379 | @canberk894 Quote:
I struggled with this problem for many days, I tried all the cph2185 flashes and the same problem, on Monday I post here the solution to revive it via usb it all started with this file https://drive.google.com/file/d/1-0v...DUKf0V05K/view Pass A15gratis or a15gratis but with this it will turn on Oppo but it will restart constantly, sorry I have written the steps in a txt but it is saved on my work pc | |
03-13-2022, 04:18 | #12 (permalink) |
Member: 2108610 Status: Offline Thanks Meter: 379 | @canberk894, Monday I post here solution, I had the same problem, I tried all the firmware cph2185 in the internet and nothing, same problem, after many tests I found the solution, I have it written in a txt in my work, I spent days looking for a way to turn it on I know that all the solution started with this file that I found, the phone will turn on Oppo but it will be restarting, so i take .images of this file and the original flash ofp and mix, i also know that the phone got to boot completely when i unmark the 3 vbmeta images https://drive.google.com/file/d/1-0v...DUKf0V05K/view Pass A15gratis or a15gratis |
The Following 2 Users Say Thank You to yosbel182us For This Useful Post: |
