01-26-2022, 11:33 | #62 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Pakistan Swat Mingora City
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Finally The mystery is solved. 1: Pandora Box 2.10 2: IMEI Repair Device Bootloop. Wipe Data from recovery didn't Help. 3: Flash https://drive.google.com/file/d/1Ff1...PI6iy8mKp/view this Firmware and device On but IMEI NULL and device status change to Oppo A94. 4: Wait for Pandora Box's new update for almost a month and finally today's update is released Pandora box 2.11. 5: IMEI Repair with Pandora Box 2.11 and device again boot loop didn't help wipe data from recovery. But this time Pandora fix the issue of multi-super.img and now we can flash ofp direct with Pandora Box 2.11. 6: I follow the procedure (AWEXSS) show me in his thread about Oppo reno 5f Repair IMEI. Thread LINK. (https://forum.gsmhosting.com/vbb/f11...-done-3002407/) 7: Flash https://androidfilehost.com/?fid=2188818919693789465 this file directs OFP with Pandora Box 2.11 and the device Turns on normally. 8: And after finally repairing IMEI with Pandora Box 2.11 and this time no problem the IMEI was repaired Successfully. Thank You Z3X Team. Flash LOG. Selected model: OPPO CPH2203 (Oppo A94) Operation: Write OFP Software version: 2.11 Extract scatter file... OK Read super info... OK Parse scatter file... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB5530E73, 0x69D78BA0, 0x471AE4EC, 0x5861B254 Get Chip ID... [MT6779] Get SOC ID... [96719D6F0A12A0D00199D66F6925087AF3376D862141BF0ABE 35BC69562E1884] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A002) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A002 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Sep 18 23:07:36 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-09-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1631976954541 Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta"... OK Download "cdt_engineering"... OK Download "md1img"... OK Download "spmfw"... OK Download "audio_dsp"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "cam_vpu1"... OK Download "cam_vpu2"... OK Download "cam_vpu3"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "super" part 1... OK Download "super" part 2... OK Download "super" part 3... OK Download "cache"... OK Download "userdata"... OK Flashing done! IMEI Repair LOG. Selected model: OPPO CPH2285 (Oppo F19 Pro) Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB5530E73, 0x69D78BA0, 0x471AE4EC, 0x5861B254 Get Chip ID... [MT6779] Get SOC ID... [96719D6F0A12A0D00199D66F6925087AF3376D862141BF0ABE 35BC69562E1884] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A002) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A002 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Mar 6 10:17:00 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1614996321774 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 356438076482449 IMEI 2: 356438076482381 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Device Screen shots. |
The Following 4 Users Say Thank You to fazalrabikhan For This Useful Post: |
04-24-2022, 14:24 | #65 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Not work for me ,set only vibrate. Selected model: OPPO CPH2203 (Oppo A94) Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Jul 24 15:57:19 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1627112788912 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 869999999999991 IMEI 2: 868888888888889 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
04-24-2022, 14:29 | #66 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Quote:
04-25-2022, 13:37 | #67 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Selected model: OPPO CPH2203 (Oppo A94) Operation: Write OFP Software version: 3.4 Extract scatter file... OK Read super info... OK Parse scatter file... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Jul 24 15:57:19 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1627112788912 Prepare list for upgrade... OK Check upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "opporeserve1"... OK Read partition "opporeserve2"... OK Read partition "opporeserve3"... OK Read partition "oppo_custom"... OK Read partition "nvcfg"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "ocdt"... OK Read partition "main_cdt"... OK Verify checksum... OK Format UFS_LU2 partition( 0x00008000..0x04107FFF )... OK Format UFS_LU2 partition( 0x0CA08000..0x0E707FFF )... OK Format UFS_LU2 partition( 0x10708000..0x16707FFF )... OK Format UFS_LU2 partition( 0x17800000..0x1787FFFF )... OK Format UFS_LU2 partition( 0x1B000000..0x1B1FFFFF )... OK Format UFS_LU2 partition( 0x20500000..0x1DC74F7FFF )... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta"... OK Download "cdt_engineering"... OK Download "md1img"... OK Download "spmfw"... OK Download "audio_dsp"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "cam_vpu1"... OK Download "cam_vpu2"... OK Download "cam_vpu3"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "super" part 1... OK Download "super" part 2... OK Download "super" part 3... OK Download "cache"... OK Download "userdata"... OK Write file "opporeserve1.bin"... OK Write file "opporeserve2.bin"... OK Write file "opporeserve3.bin"... OK Write file "oppo_custom.bin"... OK Write file "nvcfg.bin"... OK Write file "protect1.bin"... OK Write file "protect2.bin"... OK Write file "persist.bin"... OK Write file "proinfo.bin"... OK Write file "nvram.bin"... OK Write file "ocdt.bin"... OK Write file "main_cdt.bin"... OK Flashing done! Selected model: OPPO CPH2203 (Oppo A94) Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 868877777777774 IMEI 2: 869999999999991 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Downgrade & ripier but set only vaibreate.please fix this otherwise havo to bay a new phone & give to customer . |
04-25-2022, 13:39 | #68 (permalink) | |
04-26-2022, 16:02 | #71 (permalink) | |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
The Following User Says Thank You to Dooha_Bd For This Useful Post: |
05-22-2022, 13:25 | #74 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Not ork in new update. Selected model: OPPO CPH2203 (Oppo A94) Operation: Restore From Backup Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Write file "nvdata.bin"... OK Write file "nvram.bin"... OK Restore Backup done!Selected model: OPPO CPH2203 (Oppo A94) Operation: Restore From Backup Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Write file "nvdata.bin"... OK Write file "nvram.bin"... OK Restore Backup done! Selected model: OPPO CPH2203 (Oppo A94) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Read partition "nvdata"... OK Read partition "nvram"... OK Load NVDATA file error! Selected model: OPPO CPH2203 (Oppo A94) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Read partition "nvdata"... OK Read partition "nvram"... OK Load NVDATA file error! Selected model: OPPO CPH2203 (Oppo A94) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 867555555565568 IMEI 2: 867555555555544 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Selected model: OPPO CPH2203 (Oppo A94) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM57 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x59B6DCAA, 0x0A1F1B4C, 0x927187F6, 0x8F3750EB Get Chip ID... [MT6779] Get SOC ID... [6CAD7818F09DFA3607D9C9366E83A18E749100B87508AAFB7B 36D6682D11F6D7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Fri Feb 5 12:38:58 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612499246900 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 867555555565568 IMEI 2: 867555555555544 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Set only vibreate. Last edited by Dooha_Bd; 05-22-2022 at 13:32. |
05-22-2022, 14:01 | #75 (permalink) | |
