01-10-2022, 15:01 | #16 (permalink) | |
Freak Poster Join Date: Jun 2010 Location: Pakistan Swat Mingora City
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Z3x Team Help Me Quote:
Then Flash CPH2285export_11_A.21_202103310017 with CM2 and Marked Flash Formate but still the device only vibrates. Plz, Help me z3x team. | |
01-10-2022, 16:03 | #18 (permalink) |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | I repair so many oppo devices with pandora and all success without any problem. Therefore I never think about reading ful dump before Repair IMEI. 1: I repair the IMEI of Reno 5F with Pandora. 2: After Device boot loop and not solved by formatting data from recovery. 3: Then I read a dump file from the device using Pandora but untick Userdata. 4: I have a Dump file after repair IMEI. The device was in a boot loop and without userdata. But now after flashing (https://drive.google.com/file/d/1rMl...qdBeJqV5O/view) This file. Now device only vibrates. I rewrote read dump but still, the device only vibrates and nothing shows on display. |
01-10-2022, 18:13 | #23 (permalink) |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Before writing this file (CPH2217_11_F.46_2021062423012574) my phone was boot loop but after writing this file now the phone only vibrates and no other firmware works in anyway. At the end result is only vibrate. |
01-11-2022, 11:06 | #27 (permalink) |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Help Z3x Team. Firmware in PM is not flashing to the device. I try with two different tools. Pandora and CM2M2. Both tools Failed the flashing device at super.img at 99%. Result device only vibrates nothing shows on display. Pandora screenshots are attached and the CM2M2 log is below. 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM93) MODE : BOOTROM PORT : 93 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 730E53B5A08BD769ECE41A4754B26158 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 96719D6F0A12A0D00199D66F6925087AF3376D862141BF0ABE 35BC69562E1884 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 0010 EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6.00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [0C] : eUFS : LP_DDR4X : DEV : H9HQ15AFAMBDAR : RAM : [ 8.00 GB ] EMI : [0D] : eUFS : LP_DDR4X : DEV : H9HQ15AECMBDAR : RAM : [ 6.00 GB ] EMI : [0E] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMADAR : RAM : [ 8.00 GB ] EMI : [0F] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: AD014839485131354146414D42444152 UFS: VEN : 0x01AD VID : H9HQ15AFAMBDAR IFW : A002 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 201027d1a2c0000000000000 REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B93F79226974AC5F7AB1BEE7D58A534D DA : USB : HIGH-SPEED Boot done! [FL] : COMBO scatter! Update settings to UFS [FL] : Set : preloader_oppo6779.bin [FL] : Set : recovery.img [FL] : Set : opporeserve2.img [FL] : Set : vbmeta.img [FL] : Set : cdt_engineering.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : audio_dsp.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : gz.img [FL] : Set : gz.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : super.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000004108000 Erase : 0x000000000CA08000 : 0x0000000001D00000 Erase : 0x0000000010708000 : 0x0000000006000000 Erase : 0x0000000017800000 : 0x0000000000080000 Erase : 0x000000001B000000 : 0x0000000000200000 Erase : 0x0000000020500000 : 0x00000005B5300000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : OPPORESERVE2 FAIL : SEC : IMG TYPE MISMATCH Write : VBMETA Write : CDT_ENGINEERING FAIL : SEC : IMG TYPE MISMATCH Write : MD1IMG Write : SPMFW Write : AUDIO_DSP Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : CAM_VPU1 Write : CAM_VPU2 Write : CAM_VPU3 Write : GZ1 Write : GZ2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : SUPER FAIL : ERROR ERR : 0xC0010001 ERR : ERROR ERR : 0x198C00000|0x19975E938 Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
01-11-2022, 13:25 | #29 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Quote:
The Following User Says Thank You to Z3X For This Useful Post: |
01-11-2022, 14:55 | #30 (permalink) |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Dear Z3x Team Plz Help. Dear Z3x team, I know this is not the cm2 section but the team must pay attention to the post I also attached your tool screenshot. And now here is the full log of your kind tool which leads my device into a Problem. Log No. 1 Selected model: OPPO CPH2217 (Oppo Reno5 F) Operation: Flash (Download only) Software version: 2.10 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM109 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM109 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB5530E73, 0x69D78BA0, 0x471AE4EC, 0x5861B254 Get Chip ID... [MT6779] Get SOC ID... [96719D6F0A12A0D00199D66F6925087AF3376D862141BF0ABE 35BC69562E1884] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A002) Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A002 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Jul 24 15:57:19 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1627112788912 Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta"... OK Download "cdt_engineering"... OK Download "md1img"... OK Download "spmfw"... OK Download "audio_dsp"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "cam_vpu1"... OK Download "cam_vpu2"... OK Download "cam_vpu3"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "super"... error(1) Flashing done! Log No 2. Selected model: OPPO CPH2217 (Oppo Reno5 F) Operation: Flash (Download only) Software version: 2.10 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM109 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM109 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB5530E73, 0x69D78BA0, 0x471AE4EC, 0x5861B254 Get Chip ID... [MT6779] Get SOC ID... [96719D6F0A12A0D00199D66F6925087AF3376D862141BF0ABE 35BC69562E1884] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AFAMBDAR (A002) Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AFAMBDAR UFS_FWVER : A002 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta"... OK Download "cdt_engineering"... OK Download "md1img"... OK Download "spmfw"... OK Download "audio_dsp"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "cam_vpu1"... OK Download "cam_vpu2"... OK Download "cam_vpu3"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "super"... error(3) Flashing done! |
