07-13-2021, 19:17 | #16 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
07-14-2021, 07:44 | #19 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | I think now need crash pre-loader function so we can bee able to connect phone in preloadedr mode. Without need for test points And memory tool to write individual partitions Thanks |
07-19-2021, 17:49 | #25 (permalink) |
Crazy Poster Join Date: Feb 2014
Member: 2121390 Status: Offline Thanks Meter: 12 | Selected model: Alcatel UNKNOWN Operation: Read Flash Info Software version: 2.1 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM11 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3B3C85BF, 0x06E1F94C, 0xDBF4BC80, 0xB34DBF2E Get Chip ID... [MT6761] Get SOC ID... [9B252FF2BC5B46E28D0E5C780B2BA961F71042FF8FBB5E6165 B6BDBFC544745D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xF40122426977696E201042352D03382F Load EMI config from database [DB VER: 162 DB DATE: 07-09-2021] OK [0] Trying EMI [] Init EXT RAM... error(STATUS_EMI_CONTAINER_FILE_NOT_FOUND) |
07-19-2021, 18:02 | #26 (permalink) |
Member: 2121390 Status: Offline Thanks Meter: 12 | Alcatel 1L (2021) Selected model: Alcatel UNKNOWN Operation: Read Flash Info Software version: 2.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [00000000] Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM11 [BROM] Open port... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3B3C85BF, 0x06E1F94C, 0xDBF4BC80, 0xB34DBF2E Get Chip ID... [MT6761] Get SOC ID... [9B252FF2BC5B46E28D0E5C780B2BA961F71042FF8FBB5E6165 B6BDBFC544745D] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xF40122426977696E201042352D03382F Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [0] Trying EMI [] Init EXT RAM... error(STATUS_EMI_CONTAINER_FILE_NOT_FOUND) Alcatel 1L (2021) Android 11 (Go edition) Chipset Mediatek MT6761D Helio A20 (12 nm) CPU Quad-core 1.8 GHz Cortex-A53 |
07-19-2021, 20:32 | #27 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1475689 Status: Offline Thanks Meter: 2 | Nokia TA-1218 unlock failed Selected model: Nokia TA-1218 (Nokia 2V) Operation: Unlock network Software version: 2.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM241 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF280C5FB, 0xDBE9AB8B, 0x395FD141, 0xA2883302 Get Chip ID... [MT6761] Get SOC ID... [5AFFF26D127E9BD2C28910797E75CAC3338B4F66D101F73202 F4F84087E63121] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D42019236684E3771 Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [1] Trying EMI [1BB1F176, EB371E79, A29F3633, 92392267, 9C47C7D7, 0F6B3A76, A58FA23E, 4CA98027, C26ECB0F] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D42019236684E3771 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(ERR_NO_FILE) |
07-19-2021, 22:45 | #28 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,061 | Quote:
07-22-2021, 09:43 | #29 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
Where to buy box or activating? | |
