01-02-2023, 17:04 | #1 (permalink) |
Crazy Poster Join Date: Aug 2020 Location: Flash point
Member: 2965781 Status: Offline Thanks Meter: 9 | POCO M5S after patch nv corrupted [Answered] Operation: Patch CERT Software version: 4.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM40 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xC06E3D86, 0x920DB7EF, 0x59D641E5, 0x8EF09780 Get Chip ID... [MT6785] Get SOC ID... [394E15C9DE2FA666D943A1C14462EA1996D71DD85964EC6238 58390C5B080A25] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AECMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AECMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : rosemary Product Name : rosemary Product Device : rosemary Product Board : rosemary Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Thu Sep 15 21:11:17 CST 2022 Display ID : SP1A.210812.016 Security Patch : 2022-09-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : V13.0.4.0.SFFMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Load partiton for patching... OK Checking boot patch possiblity... POSSIBLE WITH BOOT UNLOCK Patching CERT... OK Save patched partiton... OK Read partitions info from phone... OK Checking A/B state... OK [B] Read security partition from phone... OK Decrypting security data... OK Encrypt security data... OK Write security partition to phone... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! If your phone after repair keeps rebooting - use wipe data option. |
