![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2014 Location: San Luis Potosi, Mexico
Member: 2109200 Status: Offline Thanks Meter: 40 | poco M5S frp not done [Solved] Selected model: Xiaomi Poco M5S (Rosemary) Operation: Erase FRP Software version: 5.1 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX] in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM12 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Release testpoint Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM12 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x886AFCAC, 0xAA6B9775, 0xD93077F0, 0xED6C007C Get Chip ID... [MT6785] Get SOC ID... [FD57D892D658C1E2676A7A82F90408E23FDC68C17401737C4F 28CD7905A167C7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AECMBDAR (A043) Load EMI config from database [DB VER: 212 DB DATE: 05-15-2023] OK [1] Trying EMI [1279C9A4] Init EXT RAM... error(6) no matter if i choose emmc or ufs |
![]() | #3 (permalink) |
Member: 2109200 Status: Offline Thanks Meter: 40 | Selected model: Xiaomi Poco M5S (Rosemary) Operation: Flash (Upgrade) Software version: 5.1 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX] in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM12 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Release testpoint Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM12 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x886AFCAC, 0xAA6B9775, 0xD93077F0, 0xED6C007C Get Chip ID... [MT6785] Get SOC ID... [FD57D892D658C1E2676A7A82F90408E23FDC68C17401737C4F 28CD7905A167C7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AECMBDAR (A043) Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AECMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Get scatter info... OK Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... [EXT4] ... OK Product Brand : Xiaomi Product Manufacturer : Xiaomi Product Model : missi Product Name : missi Product Device : missi Product Board : rosemary Board Platform : connac1x Build ID : TP1A.220624.014 Build Date : Fri May 12 16:07:15 UTC 2023 Display ID : TP1A.220624.014 Security Patch : 2023-05-01 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : V14.0.2.0.TFFMIXM Userdata FS Type : F2FS Prepare list for upgrade... OK Checking upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "nvcfg"... OK Read partition "persist"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Verify checksum... OK Format "UFS_LU2" partition( 0x00008000..0x4B807FFF )... OK Format "UFS_LU2" partition( 0x4D808000..0x57EA1FFF )... OK Format "UFS_LU2" partition( 0x5C000000..0x779FFFFF )... OK Format "UFS_LU2" partition( 0x77D00000..0x77D7FFFF )... OK Format "UFS_LU2" partition( 0x7BD80000..0xFEFFFE1DC9FF6FFF )... error(STATUS_EXCEED_AVALIABLE_RANGE) Sent from my iPhone using Tapatalk |
![]() | #7 (permalink) |
Member: 2109200 Status: Offline Thanks Meter: 40 | https://mega.nz/folder/5d8AjSDa#BoFYbtDiZbFHjwNPnqTWNA Here you go Sent from my iPhone using Tapatalk |
![]() | #10 (permalink) | |
Member: 2109200 Status: Offline Thanks Meter: 40 | Quote:
all scatter are from different xioami dedicated sites now im using this one | |
![]() | #12 (permalink) |
Member: 2109200 Status: Offline Thanks Meter: 40 | i do understand that!!! i just uploaded the scatter from the firmware im trying to flash... the point is that pandora box after tried to frp this device was killed by tool and now i cant flash it with any available firmware |
![]() | #15 (permalink) | |
Selected model: Xiaomi Poco M5S (Rosemary) Operation: Repair Software version: 5.1 Connect Type-C to NONE... OK Host Power Off... OK Connect phone to [PC] in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x886AFCAC, 0xAA6B9775, 0xD93077F0, 0xED6C007C Get Chip ID... [MT6785] Get SOC ID... [FD57D892D658C1E2676A7A82F90408E23FDC68C17401737C4F 28CD7905A167C7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AECMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AECMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... [EXT4] ... OK Product Brand : Xiaomi Product Manufacturer : Xiaomi Product Model : missi Product Name : missi Product Device : missi Product Board : rosemary Board Platform : connac1x Build ID : TP1A.220624.014 Build Date : Fri May 19 03:45:36 UTC 2023 Display ID : TP1A.220624.014 Security Patch : 2023-05-01 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : V14.0.4.0****LMIXM Userdata FS Type : F2FS Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI 2: 895202052316270 Write IMEI and patch CERT [NVDATA]... OK Load partiton for patching... OK Patching... error(1.) | |
