06-12-2021, 06:20 | #11 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 47
Member: 716581 Status: Offline Thanks Meter: 767 | OPPO A12 Wipe Data Done. Selected model: OPPO CPH2077 (Oppo A12) Operation: Wipe Data Software version: 1.13 There is a risk of data loss. This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM43 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5561CE16, 0x050B0E25, 0xCEABD163, 0x573BC05D Get Chip ID... [MT6765] Get SOC ID... [71A91F835648ED76ACBC0148D13CE452584141BB3CB7C18EAB DB8A556DF72CF7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E03518A4275171F Load EMI config from database [DB VER: 121 DB DATE: 06-07-2021] OK [1] Trying EMI [B772E8DA, 7805E65B, D8F5BD39, 4C76F2A3, BCFFEFAA, 1BB1F176, E1B3CCEC, 4ECF8C5A, 44724C4B, 148572B4] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E03518A4275171F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Format "userdata" partition... OK Wipe data done! |
