06-30-2022, 12:09 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: /system/bin Age: 31
Member: 446169 Status: Offline Sonork: 100.1601454 Thanks Meter: 30 | REAL ME X7 5g (rmx3092) SIMLOCK ISSUE!!!! [Answered] here is LOG :- Selected model: Realme RMX3092 (Realme X7 5G) Operation: Unlock network Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM67 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x93B3C80D, 0x54DBAF62, 0xFF7E20AD, 0x5E16B5DF Get Chip ID... [MT6853] Get SOC ID... [AF083439156A4F6E2DA3C74C10DEF1863302C22D82334792A7 F378C7D384483B] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [15] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ16AECMMDAR (A107) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ16AECMMDAR UFS_FWVER : A107 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6853 Board Platform : MT6853 Build ID : RP1A.200720.011 Build Date : Mon Apr 25 21:49:19 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-04-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612759478108 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Unlock... OK [DF1, DF2, GB1, GB2] Write lock info... OK Write security partition to phone... OK Network Unlock done! |
06-30-2022, 13:20 | #3 (permalink) | |
Member: 446169 Status: Offline Sonork: 100.1601454 Thanks Meter: 30 | Quote:
The Following User Says Thank You to jot_saggu For This Useful Post: |
