05-23-2022, 08:50 | #1 (permalink) |
Crazy Poster Join Date: Mar 2015 Location: iran
Member: 2365404 Status: Offline Thanks Meter: 9 | Realme 8 (RMX3085) imei Repair DONE + Files [Files inside] For Repair imei this Model You need Downgrade to : RMX3085export_11_A.20_20210916 And Select Oppo A5s DONE Code: Selected model: OPPO CPH1909 (Oppo A5s) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x88D5DB92, 0x79454E74, 0x43E6EA7B, 0x919F497E Get Chip ID... [MT6785] Get SOC ID... [9E5C979534AD7A62EB4D955E6ED5A635C03121A24B59818F3CB1F57BB0DBE3F3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V9001JM-B813 (0600) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V9001JM-B813 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6785 Board Platform : MT6785 Build ID : RP1A.200720.011 Build Date : Thu Sep 16 18:02:54 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-09-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1619430602288 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 358750061039192 IMEI 2: 358750061039549 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option.Selected model: OPPO CPH1909 (Oppo A5s) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM58 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x88D5DB92, 0x79454E74, 0x43E6EA7B, 0x919F497E Get Chip ID... [MT6785] Get SOC ID... [9E5C979534AD7A62EB4D955E6ED5A635C03121A24B59818F3CB1F57BB0DBE3F3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V9001JM-B813 (0600) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V9001JM-B813 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6785 Board Platform : MT6785 Build ID : RP1A.200720.011 Build Date : Thu Sep 16 18:02:54 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-09-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1619430602288 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 358750061039192 IMEI 2: 358750061039549 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Z3X Pandora Team Please Upload tested Frimwares to Shell we Need tested frimware to speed up Customer works tnx |
The Following 3 Users Say Thank You to mjs001 For This Useful Post: |
