04-26-2022, 13:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: null Age: 45
Member: 931565 Status: Offline Sonork: 100.1626372 Thanks Meter: 47 | REALME RMX2040 repair imei done but imei null ? how to solved this problem any solution please I try this firmware but problem same REALME_NARZO_10_RMX2040_11_C.10_2021112000260000 |
04-26-2022, 18:58 | #4 (permalink) |
Member: 931565 Status: Offline Sonork: 100.1626372 Thanks Meter: 47 | REALME RMX2040 repair imei done but imei null ? Selected model: Realme RMX2040 (Realme 6i/Narzo 10) Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5E1FC1F6, 0x3C70A1AD, 0xE6692C5B, 0x192F6C62 Get Chip ID... [MT6768] Get SOC ID... [1FA58250B17397E73A15C3CD0D20C8FF96A589FBDAD21FD826 F2375CB8607641] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B39101AE42728579D Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A394B39101AE42728579D EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1F000000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6769 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Sun Mar 20 09:50:27 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1607914664672 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 357685103580285 IMEI 2: 357685104580284 Write IMEI [NVDATA]... OK Load partiton for patching... already patched, skip Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
04-26-2022, 19:03 | #5 (permalink) |
Member: 931565 Status: Offline Sonork: 100.1626372 Thanks Meter: 47 | If your phone after repair keeps rebooting - use wipe data option. Selected model: Realme RMX2040 (Realme 6i/Narzo 10) Operation: Wipe Data Software version: 3.4 There is a risk of data loss. This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5E1FC1F6, 0x3C70A1AD, 0xE6692C5B, 0x192F6C62 Get Chip ID... [MT6768] Get SOC ID... [1FA58250B17397E73A15C3CD0D20C8FF96A589FBDAD21FD826 F2375CB8607641] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B39101AE42728579D Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A394B39101AE42728579D EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1F000000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6769 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Sun Mar 20 09:50:27 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1607914664672 Format "userdata" partition... OK Format "cache" partition... OK Create default filesystems... OK Wipe data done! |
04-28-2022, 20:17 | #7 (permalink) | |
Member: 931565 Status: Offline Sonork: 100.1626372 Thanks Meter: 47 | REALME RMX2040 repair imei done but imei null ? Quote:
DOWNGRADE successfully Flash without userdata and cache. Again IMEI REPAIR Done . But IMEI Not show *#06# Network working 100% but 4g signal not work ? | |
04-28-2022, 20:57 | #9 (permalink) |
Member: 931565 Status: Offline Sonork: 100.1626372 Thanks Meter: 47 | REALME RMX2040 repair imei done but imei null ? [IMG]test keyboard[/IMG] |
