01-26-2022, 12:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2019 Location: pakistan Age: 26
Member: 2934984 Status: Offline Sonork: 69 Thanks Meter: 46 | Realme RMX3201 (Realme C21) Imei Repair Done! [Done] Operation: Repair Software version: 2.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM48 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB05BA6C0, 0xA25A1200, 0x5D35AE5D, 0x71A9038A Get Chip ID... [MT6765] Get SOC ID... [EB47FAE9BEDDA1AEBB5CAE40EE50F9D7F60198682698D6F86F 886AB463A237C6] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E0300CDA3F9A72F Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E0300CDA3F9A72F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6765 Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Sun Sep 19 22:49:49 CST 2021 Display ID : QP1A.190711.020 release-keys Security Patch : 2021-09-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: IMEI 2: Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
The Following 6 Users Say Thank You to h3yazlan For This Useful Post: |
