06-18-2022, 06:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | oppo a54 cph 2239 after repair imei don but imei show nill [Solved] Code: Selected model: OPPO CPH2239 (Oppo A54) Operation: Repair Software version: 3.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM35 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1824AFD9, 0xB7C99BF0, 0x6C15811E, 0x4656C3EE Get Chip ID... [MT6765] Get SOC ID... [2868EA615A4B25C286855DEDC8620D3E6B017210314C344EAF014B0FB2C41F82] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E030023978A48BF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E030023978A48BF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Tue Feb 8 15:34:11 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1644304518397 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 357515891502557 IMEI 2: 357515891502565 Write IMEI [NVDATA]... OK Load partiton for patching... OK Patching CERT... already patched, skip Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
06-19-2022, 07:08 | #3 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2489055 Status: Offline Thanks Meter: 71 | Click Read IMEI Button It will tell you whether nvdata partition is good or damaged In your case it is damaged restore nvdata from good backup.Then retry your problem will be solved |
06-19-2022, 12:36 | #4 (permalink) | |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Quote:
Code: Selected model: OPPO CPH2239 (Oppo A54) Operation: Read IMEI Info Software version: 3.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM35 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1824AFD9, 0xB7C99BF0, 0x6C15811E, 0x4656C3EE Get Chip ID... [MT6765] Get SOC ID... [2868EA615A4B25C286855DEDC8620D3E6B017210314C344EAF014B0FB2C41F82] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E030023978A48BF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E030023978A48BF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Tue Feb 8 15:34:11 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1644304518397 Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK IMEI 1: 357515xxxxxxxxx IMEI 2: 35751xxxxxxxxxx Reading IMEI done! | |
06-21-2022, 01:40 | #5 (permalink) | |
