11-24-2022, 19:29 | #1 (permalink) |
Junior Member Join Date: May 2021 Location: Mexico
Member: 2988097 Status: Offline Thanks Meter: 6 | Redmi note 10 5g, canīt patch cert Thank you and best regards. Selected model: Xiaomi Redmi Note 10 5G (China) (Camellia) Operation: Patch CERT Software version: 3.10 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM122 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB2AE147F, 0x282AB99F, 0xDCAFEC01, 0x829022C8 Get Chip ID... [MT6833] Get SOC ID... [416FDB0F242FACCBB20D9492C8B94F3C0212CA7259EF601ED1 7A4B6454CE1B70] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2103K19C Product Name : camellia Product Device : camellia Product Board : camellia Board Platform : MT6833 Build ID : RP1A.200720.011 Build Date : Fri Apr 16 02:51:14 CST 2021 Display ID : AN3516-camellia-build-2021041602 Security Patch : 2021-04-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.0.1.0.RKSMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Unknown Xiaomi model! |
