10-12-2021, 08:34 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: i amm livinig in tukrey
Member: 454060 Status: Offline Thanks Meter: 12 | redmi note 9 mi account bypass fail need help [Solved] bypass mi accuont but show error in final what is the problem Selected model: Xiaomi M2003J15SC (Redmi Note 9) Operation: Reset Mi Acc Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM22 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xDCC889B6, 0x0F827FE8, 0xEF0B8E1D, 0xFFA9DA0F Get Chip ID... [MT6768] Get SOC ID... [5437C569160D22AA3B9D4BF75A75DCCE60FE891E50DFC0C81E 11901E15807C52] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A39533910030036924723 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A39533910030036924723 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1F000000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2003J15SC Product Name : merlin_global Product Device : merlin Board Platform : MT6768 Product Board : merlin Build ID : QP1A.190711.020 Build Date : Mon May 17 14:19:36 CST 2021 Display ID : AL2522-Merlin-V101-Q-0517 Security Patch : 2021-05-01 Version SDK : 29 Version Release : 10 Version Codename : REL Read security partition from phone... OK Unlock bootloader... OK Reset Mi Account... error(102) |
10-12-2021, 08:39 | #2 (permalink) |
Member: 454060 Status: Offline Thanks Meter: 12 | has succefull but after connect wifi and relock phone again make full report is ok Selected model: Xiaomi M2003J15SC (Redmi Note 9) Operation: Reset Mi Acc Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM22 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xDCC889B6, 0x0F827FE8, 0xEF0B8E1D, 0xFFA9DA0F Get Chip ID... [MT6768] Get SOC ID... [5437C569160D22AA3B9D4BF75A75DCCE60FE891E50DFC0C81E 11901E15807C52] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A39533910030036924723 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A39533910030036924723 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1F000000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2003J15SC Product Name : merlin_global Product Device : merlin Board Platform : MT6768 Product Board : merlin Build ID : QP1A.190711.020 Build Date : Mon May 17 14:19:36 CST 2021 Display ID : AL2522-Merlin-V101-Q-0517 Security Patch : 2021-05-01 Version SDK : 29 Version Release : 10 Version Codename : REL Read security partition from phone... OK Unlock bootloader... OK Reset Mi Account... OK Write security partition to phone... OK Reset Mi Acc done! |
10-12-2021, 09:19 | #4 (permalink) | |
Member: 454060 Status: Offline Thanks Meter: 12 | Quote:
but i do bypass by another tool but when connect intern relocked again so after 1st try not success i coonect internet and relock phone again after that do bypass by pandora and done | |
