04-27-2022, 20:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Algeria is a North African Age: 35
Member: 1629321 Status: Offline Thanks Meter: 823 | remdi note 10t 5g not repair imei [Answered] Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x40EE8D1C, 0xA378640C, 0x0901CB02, 0x80241BEA Get Chip ID... [MT6833] Get SOC ID... [F1962876805018EB409FC9FEB2900413D08BD077680486368A 7430F48BB0F993] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : camellia Product Name : vnd_camellia Product Device : camellia Product Board : camellia Board Platform : MT6833 Build ID : RP1A.200720.011 Build Date : Tue Mar 29 23:53:18 CST 2022 Display ID : AN3516-camellia-build-2022032923 Security Patch : 2022-03-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.5.0.RKSMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI 1: 868117053781988 IMEI 2: 868117053781996 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Now use "Patch Cert" option to comlete repair. |
04-28-2022, 07:57 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Hello. If you cannot find patch buuton - thats mean that model not supported. https://z3x-team.com/check-your-phone/ |
The Following User Says Thank You to Z3X For This Useful Post: |
04-28-2022, 22:55 | #6 (permalink) |
Freak Poster Join Date: Jun 2021 Location: north east syria Age: 31
Member: 2990103 Status: Offline Sonork: 100.1684896 no sonork Thanks Meter: 43 | 1 backup nvdata+nvram 2 unlock BL using pandora 3 with fastboot command erase nvdata and erase nvram 4 now use pandora to enter phone into meta mode. when show phone in meta unplage usb and close pandora 5 after that use modem meta tool to repair imei number 2 6 If you don't succeed then you need the eng modem and repet work I tested that and worked I hope this model will be better supported with Pandora in the future. |
The Following 3 Users Say Thank You to mnafmf For This Useful Post: |
