RMX3690 IMEI repair failed [Answered] Selected model: Realme RMX3690 (C30s) Operation: Repair Software version: 4.8 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Waiting for device... OK Device found at COM43 Port: USB\VID_1782&PID_4D00\8&1690D1FE&0&2 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Connecting to device... OK Selected processor: SC9863A_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: 002269A02A27312030004827 Read partitions info... OK Checking A/B state... OK [A] Read product info... error(6) Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 862412060519786 IMEI 2: 862412060519778 Repaired IMEI: IMEI 1: 860565057440100 IMEI 2: 860565057440118 Check security state... OK [1] Unlock bootloader... OK Patch modem check... error(not supported fs type) If your phone after repair keeps rebooting - use wipe data option. |
Hello. We working on adding this fs. |
again : not supported fs type |
Selected model: Spreadtrum Spreadtrum Operation: Repair Software version: 5.4 CPU not selected, select it first Selected model: Spreadtrum Spreadtrum Operation: Repair Software version: 5.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX or PC] Connect phone in BROM mode. Use volume key buttons or testpoint. Waiting for device... OK Device found at COM5 Port: USB\VID_1782&PID_4D00\6&36E573BD&0&2 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Port type: BROM Connecting to device... OK Selected processor: SC9863A_64 Load files... (universal) OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: 002269A03202312030000701 Read partitions info... OK Checking A/B state... OK [B] Read product info... [EROFS] ... OK Product Brand : realme Product Manufacturer : realme Product Model : milan_Natv Product Name : milan_Natv Product Device : RE58AB Product Board : milan Board Platform : sp9863a Build ID : SP1A.210812.016 Build Date : Tue May 16 17:05:05 CST 2023 Display ID : RMX3690_12.A.47 Security Patch : 2023-05-05 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : 202305161500 Userdata FS Type : F2FS Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 8652 IMEI 2: 8652 Repaired IMEI: IMEI 2: 3544 Write IMEI... OK Save NVD... OK Done! not change please solve this problem |
Patch modem check... error(not supported fs type) i have this problem |
Operation: Repair Software version: 5.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX or PC] Connect phone in BROM mode. Use volume key buttons or testpoint. Waiting for device... OK Device found at COM5 Port: USB\VID_1782&PID_4D00\6&36E573BD&0&2 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Port type: BROM Connecting to device... OK Selected processor: SC9863A_64 Load files... (universal) OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: 002269A03202312030000701 Read partitions info... OK Checking A/B state... OK [B] Read product info... [EROFS] ... OK Product Brand : realme Product Manufacturer : realme Product Model : milan_Natv Product Name : milan_Natv Product Device : RE58AB Product Board : milan Board Platform : sp9863a Build ID : SP1A.210812.016 Build Date : Tue May 16 17:05:05 CST 2023 Display ID : RMX3690_12.A.47 Security Patch : 2023-05-05 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : 202305161500 Userdata FS Type : F2FS Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 8652xxxxxxxxx IMEI 2: 8652xxxxxxxx Repaired IMEI: IMEI 2: 354xxxx Check security state... OK [1] Unlock bootloader... OK Patch modem check... error(not supported fs type) If your phone after this operation keeps rebooting - use wipe data option. |
