06-06-2021, 15:20 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Samsung a107f dead boot repair [Done: Report] Please team add full support samsung MTK dump partition, unlock bootloader, wipe partition. Selected model: Mediatek Mediatek Operation: Flash (Download only) Software version: 1.12 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM59 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xBC365590, 0x44E264F4, 0x0E20254D, 0x9F313FE8 Get Chip ID... [MT6765] Get SOC ID... [623D902C3798728D18BF7DB7CE1F9AE08C90A779B6429BFCF3 416B6499394174] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4203DDE49645676D Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D4203DDE49645676D EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Partition "userdata" changed...skip Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Generate mirror partition table... OK Download mirror partition table... OK Read major partition table... OK Check major partition table layout changed... OK Generate major partition table... OK Download major partition table... OK Download "preloader"... OK Download "md1img"... OK Download "spmfw"... OK Download "scp1"... OK Download "sspm_1"... OK Download "lk"... OK Download "steady"... OK Download "boot"... OK Download "recovery"... OK Download "dtbo"... OK Download "tee1"... OK Download "vbmeta"... OK Download "cache"... OK Download "omr"... OK Flashing done! |
The Following User Says Thank You to okello For This Useful Post: |
