09-14-2021, 06:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2016 Location: Peshawar Pakistan
Member: 2613197 Status: Offline Sonork: 100.1673396 Thanks Meter: 29 | Samsung A10s Imei repair DOne One Click [Done] Operation: Patch CERT Software version: 2.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM27 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM27 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x03639B3D, 0x9C099663, 0xE202BF85, 0x89DB9759 Get Chip ID... [MT6765] Get SOC ID... [CD86AD236C2E1DA3FE76BC90A13F8BF9E70E784D759B6FB02D A592C63E0AFDB4] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D42034EEA071E9629 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D42034EEA071E9629 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Patch CERT [NVDATA]... OK Patch CERT [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! |
09-20-2021, 14:21 | #2 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: i amm livinig in tukrey
Member: 454060 Status: Offline Thanks Meter: 12 | Quote:
09-20-2021, 14:55 | #4 (permalink) | |
in meta mode i face this problem still at here Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM66 [PRELOADER] Open port... OK Switch to META mode... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM103 [META] Open port... OK Wait for target ready... | |
09-20-2021, 14:55 | #5 (permalink) | |
if can help me by any desk more best | |
05-14-2023, 17:23 | #7 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Quote:
https://gsmserver.com/pandora-online-activation-1-year/ https://gsmserver.com/pandora-box/ | |
05-15-2023, 01:19 | #10 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
But after patch CERT, your phone will not have network and MIPI status FAIL USE pandora old version for patch cert if you lucky can use old ver. On V5 you will get problem after patch cert, like mine Hope it help | |
05-15-2023, 03:48 | #11 (permalink) |
Freak Poster Join Date: Dec 2020 Location: uy
Member: 2974382 Status: Offline Thanks Meter: 32 | Selected model: Samsung SM-A107M (Samsung Galaxy A10s) Operation: Repair Software version: 5.0 Work ID: 2234255 Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM5 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7EEBC095, 0xAA845A7D, 0xE516D688, 0x71B2C74C Get Chip ID... [MT6765] Get SOC ID... [C89FAF049D78C156E315FC6D1E0B65FCBE79DF61F1A5F6465C FE8FC2C131F941] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4203FD766AB53749 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: QD63MB EMMC_ID : 0x150100514436334D4203FD766AB53749 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... [EXT4] ... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A107M Product Name : S96116AA1 Product Device : a10s Product Board : S96116RA1 Board Platform : MT6765 Build ID : RP1A.200720.012 Build Date : Fri Feb 11 07:19:59 KST 2022 Display ID : RP1A.200720.012.A107MUBU6CVB1 Security Patch : 2022-02-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A107MUBU6CVB1 Userdata FS Type : EXT4 Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI: 35472------ Repairing IMEI... IMEI: 35472-------- Patch CERT [NVDATA]... OK Patch CERT [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! Selected model: Samsung SM-A107M (Samsung Galaxy A10s) Operation: Patch CERT Software version: 5.0 Work ID: 2234295 Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM5 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7EEBC095, 0xAA845A7D, 0xE516D688, 0x71B2C74C Get Chip ID... [MT6765] Get SOC ID... [C89FAF049D78C156E315FC6D1E0B65FCBE79DF61F1A5F6465C FE8FC2C131F941] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4203FD766AB53749 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: QD63MB EMMC_ID : 0x150100514436334D4203FD766AB53749 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... [EXT4] ... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A107M Product Name : S96116AA1 Product Device : a10s Product Board : S96116RA1 Board Platform : MT6765 Build ID : RP1A.200720.012 Build Date : Fri Feb 11 07:19:59 KST 2022 Display ID : RP1A.200720.012.A107MUBU6CVB1 Security Patch : 2022-02-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A107MUBU6CVB1 Userdata FS Type : EXT4 Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! |
05-15-2023, 03:53 | #12 (permalink) |
05-18-2023, 17:34 | #14 (permalink) | |
Member: 2974382 Status: Offline Thanks Meter: 32 | Quote:
