04-30-2021, 10:44 | #1 (permalink) |
Freak Poster Join Date: Nov 2019 Location: South Africa Age: 33
Member: 2934673 Status: Offline Sonork: Still Not Created Thanks Meter: 218 | Vivo 1938 (Y30) Bootloader Unlock AND IMEI REPAIR DONE https://i.ibb.co/L9mRNnM/ice-screens...430-023725.jpg Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM82 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x786FCE9A, 0x66BC9857, 0x5C329856, 0xEEB17CFE Get Chip ID... [MT6765] Get SOC ID... [F5703CA0885EA1F909C6BA7CC7E819C500C74207CFE8AB8DCB 145E4806A2BDAD] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B39101B1667205785 Load EMI config from database [DB VER: 79 DB DATE: 04-28-2021] OK [1] Trying EMI [703B5CDE, F83EEC01, 4C76F2A3, 40457DA8, D6C7319B, 4ECF8C5A, C41C94FB, F1ADA01B, 667E0B28] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A394B39101B1667205785 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1F000000 (116,48Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Reading security from phone... OK IMEI 1: 000000000000000 IMEI 2: 000000000000000 Set new IMEI to: IMEI 1: 350455465452540 IMEI 2: 354674564545485 Searching security key... found! [1] Writing security to phone... OK Repair Security done! |
The Following 5 Users Say Thank You to GSM.AFRICA For This Useful Post: |
05-01-2021, 15:03 | #2 (permalink) |
Freak Poster Join Date: Sep 2015 Location: Lombok
Member: 2465890 Status: Offline Thanks Meter: 176 | does it support change to new imei for normal phone? your phone has imei corrupt. please tell us. I'm going to buy this box |
The Following User Says Thank You to AWEXSS For This Useful Post: |
