06-25-2022, 11:31 | #1 (permalink) |
Freak Poster Join Date: Mar 2018
Member: 2824019 Status: Offline Thanks Meter: 83 | Vivo PD1934F Y19Receive DA SYNC signal error [Solved] Operation: Repair Software version: 3.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6AC1E587, 0xF1773A8B, 0x1E278CA9, 0x850D3F30 Get Chip ID... [MT6768] Get SOC ID... [B45CC9D2BB85791FD9CE971A603D9165EFAE7991B87AF79E64 57BA401255CCBA] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1) |
06-26-2022, 07:47 | #4 (permalink) |
Member: 2824019 Status: Offline Thanks Meter: 83 | Solved Not Connecting on volume up and down After power in and change cables Same error Tp mode Success , Repair done all is ok But Write partition "nvdata"... error(3) ? I think Its latest Security Patch issue . Selected model: Vivo PD1934F (Y19) Operation: Repair Software version: 3.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6AC1E587, 0xF1773A8B, 0x1E278CA9, 0x850D3F30 Get Chip ID... [MT6768] Get SOC ID... [B45CC9D2BB85791FD9CE971A603D9165EFAE7991B87AF79E64 57BA401255CCBA] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B391015278B2DB653 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A394B391015278B2DB653 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1F000000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : vivo Product Manufacturer : vivo Product Model : vivo 1915 Product Name : 1915N Product Device : 1915 Product Board : k68v1_64 Board Platform : MTK6768 Build ID : SP1A.210812.003 Build Date : Mon May 9 22:54:04 CST 2022 Display ID : Funtouch OS_10.5 Security Patch : 2022-05-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : 8.71.20 Reading security from phone... OK IMEI 1: 357192103686543 IMEI 2: 357193103686541 Set new IMEI to: IMEI 1: 357192103686543 IMEI 2: 357193103686541 Searching security key... found! [3] Writing security to phone... OK Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: xxxxxxxxxxxxxxxx IMEI 2: xxxxxxxxxxxxxxxx Repairing IMEI... IMEI 1: 357xxxxxxxxxxxxx IMEI 2: 357xxxxxxxxxxxxx Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... error(3) |
