Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 06-25-2022, 11:31   #1 (permalink)
Member: 2824019
Thanks Meter: 83
Vivo PD1934F Y19Receive DA SYNC signal error [Solved]
Selected model: Vivo PD1934F (Y19)
Operation: Repair
Software version: 3.6
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM4 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0707
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6768]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x6AC1E587, 0xF1773A8B, 0x1E278CA9, 0x850D3F30
Get Chip ID... [MT6768]
Get SOC ID... [B45CC9D2BB85791FD9CE971A603D9165EFAE7991B87AF79E64 57BA401255CCBA]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [8]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... error(1)
Old 06-25-2022, 13:34   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,062
Hello. Try change cables and try add extra power via power adaptor.
Old 06-25-2022, 22:47   #3 (permalink)
Member: 2793383
Thanks Meter: 57
Hardware lines damages check clk lines
Old 06-26-2022, 07:47   #4 (permalink)
Member: 2824019
Thanks Meter: 83
Solved
Not Connecting on volume up and down
After power in and change cables Same error
Tp mode Success , Repair done all is ok
But Write partition "nvdata"... error(3) ?
I think Its latest Security Patch issue .
Operation: Repair
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB VCOM (Android),usb2ser.sys,3.0.1504.0]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x13014E53304A394B391015278B2DB653
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x13014E53304A394B391015278B2DB653
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x1D1F000000 (116.48Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand : vivo
Product Manufacturer : vivo
Product Model : vivo 1915
Product Name : 1915N
Product Device : 1915
Product Board : k68v1_64
Board Platform : MTK6768
Build ID : SP1A.210812.003
Build Date : Mon May 9 22:54:04 CST 2022
Display ID : Funtouch OS_10.5
Security Patch : 2022-05-01
Version SDK : 31
Version Release : 12
Version Codename : REL
Firmware Version : 8.71.20
Reading security from phone... OK
IMEI 1: 357192103686543
IMEI 2: 357193103686541
Set new IMEI to:
Searching security key... found! [3]
Writing security to phone... OK
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... OK
IMEI 1: xxxxxxxxxxxxxxxx
IMEI 2: xxxxxxxxxxxxxxxx
Repairing IMEI...
IMEI 1: 357xxxxxxxxxxxxx
IMEI 2: 357xxxxxxxxxxxxx
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Page generated in 0.15133 seconds with 8 queries
