10-07-2021, 12:01
#4 (permalink)
Member: 15521
Thanks Meter: 57 | Write OFP button is OK. Sory I missed this and try Write Firmware only. But have other problem now. All parts write without "super.img". After load ofp file no checkbox for super.img. But when I unpack ofp by "EasyJTAG Plus" i have this files:
super.0.657f6b4e.img
super.1.7dff8c51.img
super.2.dd54fcc8.img
How write this three parts super.img from .ofp file? Quote:
Extract scatter file... OK
Parse scatter file... OK
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0950
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6893]
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM742 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x2060674C, 0xDEA8146A, 0x1740E663, 0x14640A52
Get Chip ID... [MT6893]
Get SOC ID... [903080C9B9632800CAF801D17CECBAFFEDFCFB39A2FB2CE8C0 EA4C68693DA21A]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [31]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
UFS CID (FW VER): KLUDG4UHDB-B2D1 (1903)
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : KLUDG4UHDB-B2D1
UFS_FWVER : 1903
BLOCK_SIZE: 0x0000001000 (4,00Kb)
UFS_LU0 : 0x0000400000 (4,00Mb)
UFS_LU1 : 0x0000400000 (4,00Mb)
UFS_LU2 : 0x1DCB000000 (119,17Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448,00Kb)
EXT_RAM : 0x0100000000 (4,00Gb)
Get scatter info... OK
Check USB status... USB_HIGH_SPEED
Verify scatter file... OK
Do NAND BMT remark... OK
Setup download info... OK
Get partition table catagory... OK [GPT]
Read mirror partition table... OK
Check partition table layout changed... OK
Read major partition table... OK
Check major partition table layout changed... OK
Download "preloader"... OK
Download "recovery"... OK
Download "opporeserve2"... OK
Download "vbmeta"... OK
Download "vbmeta_system"... OK
Download "vbmeta_vendor"... OK
Download "cdt_engineering"... OK
Download "md1img"... OK
Download "spmfw"... OK
Download "audio_dsp"... OK
Download "pi_img"... OK
Download "dpm_1"... OK
Download "dpm_2"... OK
Download "scp1"... OK
Download "scp2"... OK
Download "sspm_1"... OK
Download "sspm_2"... OK
Download "mcupm_1"... OK
Download "mcupm_2"... OK
Download "cam_vpu1"... OK
Download "cam_vpu2"... OK
Download "cam_vpu3"... OK
Download "gz1"... OK
Download "gz2"... OK
Download "lk"... OK
Download "lk2"... OK
Download "boot"... OK
Download "logo"... OK
Download "dtbo"... OK
Download "tee1"... OK
Download "tee2"... OK
Download "cache"... OK
Download "userdata"... OK
Flashing done!
