10-25-2022, 13:19 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: algeria
Member: 2534809 Status: Offline Sonork: https://www.facebook.com/ Thanks Meter: 8 | help me sir ipad 6 wif passcode cant baypass Info : iPad (6th gen, WiFi) [iPad7,5-j71bap] Boot : [IBOOT-2696.0.0.1.33] [DFU] Pwnder : CHECKM8 Initializing... OK Sending ibss.img4... OK Sending ibec.img4... OK Executing loader... OK Sending devicetree.img4... OK Sending ramdisk.img4... OK Sending rdtrust.img4... OK Sending kernel.img4... OK Booting RAMDISK... OK UNLOCKTOOL 2022.10.24.0 Elapsed time : 48 seconds[COLOR=#444444;]FIX MOUNT[/COLOR] Initializing... OK Connecting to device... OK If tool got hang on fixing mount, just disconnect cable then reconnect cable then try Fix Mount again! Fixing mount... OK UNLOCKTOOL 2022.10.24.0 Elapsed time : 28 seconds Initializing... OK Connecting to device... OK Mounting system... FAIL Failed to mount partitions! Try Fix Mount or select another RAMDISK! Failed to locate activation data! UNLOCKTOOL 2022.10.24.0 Elapsed time : 12 seconds always error i have tryed all ipwnd mode gaster ..same problem all boot 1 and 2 always fail |
10-25-2022, 20:00 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,798 | checkm8 works absolutly normal with that device. (ramdisk works also normal). have you tried re-plugging device and repating backup option ? p.s. is the device on ios 15.x ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
