iPad 6 Big problem loading Ramdisk Anybody please do you have any working solution for this idiotic device which I am fighting with for hours and unable to load ramdisk? As soon as UT starts sending those files ibss the iPad powers up like a ****ing device?: BOOT RAMDISK Checking for device... OK Info : iPad (6th gen, Cellular) [iPad7,6-j72bap] Boot : [IBOOT-2696.0.0.1.33] [DFU] Pwnder : CHECKM8 Initializing... OK Sending ssh... OK Sending ibss.img4... OK Sending ibec.img4... FAIL ERROR: Unable to connect to device Tips : If device keeps booting up while sending ibss or ibec Press and Hold VOLUME DOWN + POWER while sending ibss and ibec After done sending ibss and ibec you can release those buttons. BOOT RAMDISK Checking for device... OK I tried holding power and Volume down button still the same. Tried also holding forever since the begining of the PWNDFU putting stage but the same always. Thanks |
Check the driver Tx |
1 Attachment(s) Quote:
then you need to fix drivers. b.r. Alex |
Thanks all for getting involved to help but it is not driver issue at all So I fixed by writing this beta IOS 15.6 firmware https://updates.cdn-apple.com/2022Su...9_Restore.ipsw (as long as Apple still signs it) and then holding just volume down during the last part of pwndfu process with EFT (keep in mind that UT PWNDFU is still broken for me - doesn't work at all) and until the end of load Ramdisk process |
Thanks all for getting involved to help but it is not driver issue at all So I fixed by writing this beta IOS 15.6 firmware https://updates.cdn-apple.com/2022Su...9_Restore.ipsw (as long as Apple still signs it) and then holding just volume down during the last part of pwndfu process with EFT (keep in mind that UT PWNDFU is still broken for me - doesn't work at all) and until the end of load Ramdisk process Br |
I fixed driver and changed pwndfu but not work i will try to downgrade to 15.7rc |
iPad6 is very sensitive about PWNer, In my case, it works only when PWNed on MAC, with every pwner it boots ramdisk, but not final step. With good PWN it goes fully and works. thats just another hint about ramdisk. b.r. Alex |
2 Attachment(s) just did some testing with iPad6 ... here are the results : (as I wrote before, not every PWNer will boot ramdisk till the end) ios 15.7: - ramdisk (generics1) boots normal - backup normal, erase / restore normal, device starts normal ios16.1.1: - ramdisk ios 16.x.x Does not work. Always error. - ramdisk Generics1 boot normal, backup normal (did not make restore backup) - device after process in bootloop - reflashing with 3uTools puts it back to life, with userdata retained (it was previously on same ios 16.1.1) pictures attached. b.r. Alex |
same error with ipad 5th wifi need help |
Clean windows, correct drivers and everything will work. B.r Alex |
samething BOOT RAMDISK Checking for device... OK Info : iPad Air 2 (Cellular) [iPad5,4-j82ap] Boot : [IBOOT-1991.0.0.2.16] [DFU] Pwnder : GASTER Initializing... OK Sending ssh... OK Sending ibss.img4... FAIL No response from device! Sending ibss.img4... FAIL No response from device! Tips : If device keeps booting up while sending ibss or ibec Press and Hold VOLUME DOWN + POWER while sending ibss and ibec After done sending ibss and ibec you can release those buttons. |
use correct drivers, PWN on mac, clean pc, and will work. b.r. Alex |
no one to help ??? please help |
