01-20-2023, 13:04 | #1 (permalink) |
Junior Member Join Date: Mar 2017 Location: India
Member: 2696225 Status: Offline Thanks Meter: 7 | Iphone 7 IOS 15.7.1 Passcode Disable Bypass with Network Successfully with Unlock Too Iphone 7 IOS 15.7.1 Passcode Disable Bypass with Network Successfully with Unlock Tool Code: PWNDFU Please enable Test Mode if needed! Tips : Goto Config and Disable Driver Signature then reboot PC! Installing drivers... OK Pwning DFU [GASTER] (x64)... OK Install 64-bit driver... OK UNLOCKTOOL 2023.01.13.1 Elapsed time : 20 seconds Code: BOOT RAMDISK Checking for device... OK Info : iPhone 7 (GSM) [iPhone9,3-d101ap] Boot : [IBOOT-2696.0.0.1.33] [DFU] Pwnder : GASTER Initializing... OK Sending iboot.img4... OK Sending devicetree.img4... OK Sending ramdisk.img4... OK Sending rdtrust.img4... OK Sending kernel.img4... OK Booting RAMDISK... OK UNLOCKTOOL 2023.01.13.1 Elapsed time : 37 seconds Code: CREATE ICINFO.SISV Initializing... OK Connecting to device... OK Generating ICinfo.sisv... Mounting system... FAIL Try fixing mount... Initializing disks... OK Mounting xART... OK Mounting Baseband Data... OK Mounting Hardware... OK Mounting Preboot... OK Mounting Data... OK Ramdisk mount success! OK Saved to : C:\UnlockTool\Backups\LOCKDOWN\IC-Info.sisv_0x0xxxx5060044xxxx UNLOCKTOOL 2023.01.13.1 Elapsed time : 3 seconds Code: FACTORY RESET Initializing... OK Connecting to device... OK Mounting system... FAIL Try fixing mount... Initializing disks... OK Mounting xART... OK Mounting Baseband Data... OK Mounting Hardware... OK Mounting Preboot... OK Mounting Data... OK Ramdisk mount success! Erasing all... OK UNLOCKTOOL 2023.01.13.1 Elapsed time : 33 seconds Code: RESTORE BACKUP Initializing... OK Connecting to device... OK Mounting system... FAIL Try fixing mount... Initializing disks... OK Mounting xART... OK Mounting Baseband Data... OK Mounting Hardware... OK Mounting Preboot... OK Mounting Data... OK Ramdisk mount success! Backup found : 0x00xxxx060044xxxx.zip Initializing... OK Restoring data.. OK UNLOCKTOOL 2023.01.13.1 Elapsed time : 36 seconds |
