04-26-2022, 11:50 | #1 (permalink) |
Freak Poster Join Date: Mar 2022 Location: fsd Age: 23
Member: 3008540 Status: Offline Thanks Meter: 17 | Oppo a54 cph2203 factory reset and bootloader unlock and repair with tr tool Verifying user information. Successful Program version : 1.0.3.9 Process name : Mtk Imei Repair (Adb and Flash Methot) (PERMANENT IMEI !!!) Process model name : Oppo Oppo A94 (CPH2203) Waiting adb connection. Found. Port Information : Name : WinUsb Device Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&13913dba&0&0001# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Open adb path. Succesfuly Check adb connection. Succesfuly Reading device information. Succesfuly Brand name : alps Model name : oppo6779 Release : 11 Security version : 2021-02-05 Display id : CPH2203_11_A.01_210205 Date : 1612499938 Description : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1612499246900 release-keys Cpu version : arm64-v8a Locale : en-US Id : RP1A.200720.011 Serial number : LF7DBIR46SRWSWKZ Security partition : nvram,nvdata Frp partition : /dev/block/by-name/frp LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 56 Path : \\.\usb#vid_0e8d&pid_0003#6&284a7c69&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6779 (Helio P90 k79v1) Hardware code : 0x00000725 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 2E8EA3CC1F86FBDAC5B7F7D3986DA31D Get socid. Succesfuly Meid : 8EDD0E6564F6335F4277C9D38B2C162033A474968A371B24EC 13475CA5395EDE Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6779.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 512 KB (0x0000000000200000) DRAM size : 512 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 119.17 GB Disk cid : KM8V8001JM-B81 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 51 Download protocol start. Succesfuly Backup nvram file. Succesfuly Backup count : 3 Path : C:\Program Files (x86)\Tr Tools PRO\Backup\Mtk\Calibration\Flash Mode\Oppo A94 (CPH2203)-2022-04-26-15-40-29.tr Clear calibration data. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Waiting adb connection. Found. Port Information : Name : WinUsb Device Path : \\.\usb#vid_22d9&pid_2765&mi_01#7&13913dba&0&0001# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} The device is expected to be ready. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port Number : 56 Path : \\.\usb#vid_0e8d&pid_0003#6&284a7c69&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6779 (Helio P90 k79v1) Hardware code : 0x00000725 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 2E8EA3CC1F86FBDAC5B7F7D3986DA31D Get socid. Succesfuly Meid : 8EDD0E6564F6335F4277C9D38B2C162033A474968A371B24EC 13475CA5395EDE Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6779.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 512 KB (0x0000000000200000) DRAM size : 512 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : uFS Disk size : 119.17 GB Disk cid : KM8V8001JM-B81 Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 51 Download protocol start. Succesfuly Fast methot init. Succesfuly First imei calculation from server. Succesfuly Second imei calculation from server. Succesfuly The calculated file is written to the device. Succesfuly Patch cert. Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 258 .s Process number : 582770 |
