04-30-2022, 12:09 | #1 (permalink) |
Freak Poster Join Date: Mar 2022 Location: fsd Age: 23
Member: 3008540 Status: Offline Thanks Meter: 17 | Oppo a5s bootloader unlock and repair with trtool pro Verifying user information. Successful Program version : 1.0.4.0 Process name : Mtk Flash Mode Toolkit (Disable Orange State) Process model name : Oppo A5s (CPH1909) LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : USB Serial Device Number : 11 Path : \\.\usb#vid_0e8d&pid_0003#5&3a808860&0&5#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6765 (Helio P35/G35) Hardware code : 0x00000766 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0000 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 41E2414BAAD6C8F16D2458328740698D Get socid. Succesfuly Meid : A245214A8F74B6AB66C405AB3EE0DE22FAFD60A47E9E7F6A2C 39A096A52680A9 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_oppo6765_18511.bin Emi version : V116 Searching da from server. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 232 KB (0x0000000000200000) DRAM size : 232 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 29.12 GB Disk cid : JhB8aP Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 40 Download protocol start. Succesfuly Reading device information. Succesfuly Release : 8.1.0 Security version : 2021-04-05 Description : full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys Cpu version : arm64-v8a Locale : en-US Id : O11019 Disabling orange state... Succesfuly Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 54 .s Process number : 608183 |
The Following 2 Users Say Thank You to shahidm2 For This Useful Post: |
