FactoryFilePak | 04-15-2022 13:28 | Tecno KC2 (Sprak 4) MTK6761/MT6762 Read Flash File Done By TR Tools PRO Tecno KC2 (Sprak 4) MTK6761/MT6762 Read Flash File Done By TR Tools PRO Code:
Verifying user information. Successful
Program version : 1.0.3.8
Process name : Mtk Read or Format Firmware
Process model name : Tecno Spark 4 Lite
LibUsb checking and installing. Succesfuly
Preloader mode: Turn off the device and plug in a usb cable.
Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button.
Waiting preloader or brom port. Found.
Port Information :
Name : MediaTek PreLoader USB VCOM_V1633 (Android)
Number : 4
Path : \\.\usb#vid_0e8d&pid_2000#5&31036e8e&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Connection Mode : Preloader
Preloader switch brom mode. Succesfuly
Port Information :
Name : MediaTek USB Port_V1633
Number : 3
Path : \\.\usb#vid_0e8d&pid_0003#5&31036e8e&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Brom
Connect mtk port. Succesfuly
Connecting brom mode. Succesfuly
Reading cpu information. Succesfuly
Cpu name : MT6761/MT6762/MT3369/MT8766B (Helio A20/P22/A22/A25/G25)
Hardware code : 0x00000717
Hardware sub code : 0x8A00
Hardware version : 0xCA00
Sw version : 0x0200
Disabling watchdog. Succesfuly
Get config target. Succesfuly
SBC status : Active
SLA status : Passive
DAA status : Active
SWJTAG status : Active
EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive
Root cert required : Passive
Memory read auth : Active
Memory write auth : Active
Cmd 0xC8 blocked : Active
Get meid. Succesfuly
Meid : 130933393E2DCC3B9893AC1DB81AA27E
Get socid. Succesfuly
Meid : B3270615CB2283F389904E7A0FD4BA0AF68F8697BE4AEFD8737E28832F5F0574
Security bypass methot : Kamakiri2
Bypass security. Succesfuly
Reading emi from device. Succesfuly
Loading preloader file. Succesfuly
Emi name : preloader_kc2_h6113.bin
Emi version : V116
Searching da from server. Succesfuly
File is approved from the server. Succesfuly
Downloading file. Succesfuly
Da load mode : Stream
File is being verified. Succesfuly
Loading da file. Succesfuly
Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394
Da identifier : MTK_DOWNLOAD_AGENT
Search entry. Succesfuly
Flash protocol : XFlash
Sending boot. Succesfuly
Jump first boot. Succesfuly
Set flash mode device. Succesfuly
Get flash mode. Succesfuly
Flash mode : brom
Get ram information. Succesfuly
SRAM size : 233 KB (0x0000000000200000)
DRAM size : 233 KB (0x0000000000200000)
Get storage information. Succesfuly
Send emi data. Succesfuly
Send second boot. Succesfuly
Storage type : eMMC
Disk size : 29.12 GB
Disk cid : GD6BM
Check storage life. Succesfuly
Reading device partition. Succesfuly
Part count : 39
Download protocol start. Succesfuly
Reading device information. Succesfuly
Brand name : TECNO
Model name : TECNO KC2
Release : 9
Security version : 2021-07-05
Display id : KC2-H6113AI-P-210705V320
Date : 1625478852
Description : full_kc2_h6113-user 9 PPR1.180610.011 126295 release-keys
Cpu version : arm64-v8a
Locale : en-US
Write list partition. Succesfuly
Listing successful. Do not disconnect the device.You can read, write and format from the section list by pressing the right mouse button.
Process name : Read Selected Partition
Backup count : 38
Total size : 5.06 GB
Save path : C:\Program Files (x86)\Tr Tools PRO\Backup\Firmware\Tecno-Spark 4 Lite-2022-04-15-16-54-05.tr
Start backup firmware. Succesfuly
Making file map header. Succesfuly
seccfg.
sec1.
md1img.
spmfw.
scp1.
scp2.
sspm_1.
sspm_2.
gz1.
gz2.
nvram.
lk.
lk2.
boot.
logo.
dtbo.
tee1.
tee2.
vendor.
system.
vbmeta.
persist.
protect1.
protect2.
cache.
recovery.
tkv.
proinfo.
para.
metadata.
boot_para.
expdb.
frp.
tranfs.
nvcfg.
nvdata.
otp.
flashinfo.
Download protocol finish. Succesfuly
Reboot device. Succesfuly
Process status : Successful
Process time : 1172 .s
Process number : 521556 https://i.imgur.com/WYhUkMs.png Br
FactoryFilePak |
