04-15-2022, 13:28 | #1 (permalink) |
Product Supporter Join Date: Jul 2015 Location: pk
Member: 2436842 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,937 | Tecno KC2 (Sprak 4) MTK6761/MT6762 Read Flash File Done By TR Tools PRO Tecno KC2 (Sprak 4) MTK6761/MT6762 Read Flash File Done By TR Tools PRO Code: Verifying user information. Successful Program version : 1.0.3.8 Process name : Mtk Read or Format Firmware Process model name : Tecno Spark 4 Lite LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek PreLoader USB VCOM_V1633 (Android) Number : 4 Path : \\.\usb#vid_0e8d&pid_2000#5&31036e8e&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Connection Mode : Preloader Preloader switch brom mode. Succesfuly LibUsb checking and installing. Succesfuly Preloader mode: Turn off the device and plug in a usb cable. Brom mode: Turn off the device, connect the usb cable by pressing the volume up and down button. Waiting preloader or brom port. Found. Port Information : Name : MediaTek USB Port_V1633 Number : 3 Path : \\.\usb#vid_0e8d&pid_0003#5&31036e8e&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Brom Connect mtk port. Succesfuly Connecting brom mode. Succesfuly Reading cpu information. Succesfuly Cpu name : MT6761/MT6762/MT3369/MT8766B (Helio A20/P22/A22/A25/G25) Hardware code : 0x00000717 Hardware sub code : 0x8A00 Hardware version : 0xCA00 Sw version : 0x0200 Disabling watchdog. Succesfuly Get config target. Succesfuly SBC status : Active SLA status : Passive DAA status : Active SWJTAG status : Active EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT : Passive Root cert required : Passive Memory read auth : Active Memory write auth : Active Cmd 0xC8 blocked : Active Get meid. Succesfuly Meid : 130933393E2DCC3B9893AC1DB81AA27E Get socid. Succesfuly Meid : B3270615CB2283F389904E7A0FD4BA0AF68F8697BE4AEFD8737E28832F5F0574 Security bypass methot : Kamakiri2 Bypass security. Succesfuly Connecting brom mode. Succesfuly Reading emi from device. Succesfuly Loading preloader file. Succesfuly Emi name : preloader_kc2_h6113.bin Emi version : V116 Searching da from server. Succesfuly File is approved from the server. Succesfuly Downloading file. Succesfuly Da load mode : Stream File is being verified. Succesfuly Loading da file. Succesfuly Da version : MTK_AllInOne_DA_v3.3001.09/05/2021.05:41_572394 Da identifier : MTK_DOWNLOAD_AGENT Search entry. Succesfuly Flash protocol : XFlash Sending boot. Succesfuly Jump first boot. Succesfuly Set flash mode device. Succesfuly Get flash mode. Succesfuly Flash mode : brom Get ram information. Succesfuly SRAM size : 233 KB (0x0000000000200000) DRAM size : 233 KB (0x0000000000200000) Get storage information. Succesfuly Send emi data. Succesfuly Send second boot. Succesfuly Get storage information. Succesfuly Storage type : eMMC Disk size : 29.12 GB Disk cid : GD6BM Check storage life. Succesfuly Reading device partition. Succesfuly Part count : 39 Download protocol start. Succesfuly Reading device information. Succesfuly Brand name : TECNO Model name : TECNO KC2 Release : 9 Security version : 2021-07-05 Display id : KC2-H6113AI-P-210705V320 Date : 1625478852 Description : full_kc2_h6113-user 9 PPR1.180610.011 126295 release-keys Cpu version : arm64-v8a Locale : en-US Id : PPR1.180610.011 Write list partition. Succesfuly Listing successful. Do not disconnect the device.You can read, write and format from the section list by pressing the right mouse button. Process name : Read Selected Partition Backup count : 38 Total size : 5.06 GB Save path : C:\Program Files (x86)\Tr Tools PRO\Backup\Firmware\Tecno-Spark 4 Lite-2022-04-15-16-54-05.tr Start backup firmware. Succesfuly Making file map header. Succesfuly seccfg. sec1. md1img. spmfw. scp1. scp2. sspm_1. sspm_2. gz1. gz2. nvram. lk. lk2. boot. logo. dtbo. tee1. tee2. vendor. system. vbmeta. persist. protect1. protect2. cache. recovery. tkv. proinfo. para. metadata. boot_para. expdb. frp. tranfs. nvcfg. nvdata. otp. flashinfo. Download protocol finish. Succesfuly Reboot device. Succesfuly Process status : Successful Process time : 1172 .s Process number : 521556 Br FactoryFilePak |
