09-27-2023, 20:07 | #301 (permalink) |
No Life Poster Join Date: May 2005 Location: ((EGYPT)) walid badr Age: 44
Member: 148424 Status: Online Sonork: 100.93619 Thanks Meter: 112 | x669d mdm done Brand : Infinix Model : X669D - Hot 30i NFC Exe Name : TFM Tool Pro SPD V1.5.0 Exe Version : v1.5.0 Action : Unlock Bootloader Checking account info... UserName: walidbadr Expire Date: 2024-09-27 18:04:04 Balance: 0.00 USD Retriving data...Ok Power Off Your Device & wait 10-15 seconds.... Press and hold BootKey ( Both Vol Or Vol+ Or Vol- ) As Device Base. Insert cable in device! Waiting for usb device... Detected: SPRD U2S Diag (COM18) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.19.38.134 Driver Date 1-8-2020 Initializing connection...Ok Checking baud...SPRD3 Sending fdl...Ok Waiting for usb device... Detected: SPRD U2S Diag (COM18) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.19.38.134 Driver Date 1-8-2020 Kick fdl...Spreadtrum Boot Block version 1.1 Sending second loader...Ok Authentication needed! Generating blob key...Ok Writing blob key...Failed Using Second Server... Generating blob key...Ok Writing blob key...Ok Resetting MDM Lock...Ok Note: Do, Factory Reset from recovery mode .Otherwise, you can use factory reset in diag mode Rebooting phone... Reboot done... Operation Finished! |
09-28-2023, 22:13 | #302 (permalink) |
Member: 148424 Status: Online Sonork: 100.93619 Thanks Meter: 112 | infinix gt 10 pro mdm done Brand : Infinix Model : X6739-GT 10 Pro(Auth) Exe Name : TFM Tool Pro MTK v1.9.4 Exe Version : v1.9.4 Action : MDM Remove (Tecno/Infinix) Checking account info... UserName: walidbadr Expire Date: 2024-09-27 18:04:04 Balance: 0.00 USD Downloading da file...Ok Waiting for usb device... Detected MediaTek PreLoader USB VCOM_V1632 (Android) (COM40) Driver Details Driver MF MediaTek Inc. Driver Name wdm_usb Driver Version 3.0.1504.0 Driver Date 1-22-2015 Connecting to brom... Successfully connected with brom! Brom Information... Chip : MT6893 Hw Code : 0x950 Meid : 5d05e01025ce4b0911df539f60ad88a2 Downloading resource2...Ok Initializing resource2...Ok Downloading first da... Transferring control to DA...Ok Syncing 1st DA sync char...Ok Syncing 2nd DA sync char...Ok 1st da successfully sended Downloading second da...Ok Usb Speed Status : High-Speed DA Information.... Boot information... Chip ID : 0xca008a000950 Storage : UFS CID : KLUEG4RHGB-B0E1 Vendor : 01CE LU0 : 4.00MB LU1 : 4.00MB LU2 : 238.34GB MLC : 0x1 SLC : 0x1 EOL : 0x1 LCycle : 0x0 Reading partition....Ok Removing MDM...Ok Rebooting phone...Ok Operation Finished! Elasped Time : [00:min:04:sec] Saving logs... Operation/Work ID: 3943815 |
The Following User Says Thank You to mr.6630 For This Useful Post: |
10-05-2023, 09:20 | #303 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Sabia >Gizan>KSA
Member: 978854 Status: Offline Thanks Meter: 33 | BF7 mdm By selecting Tecno>0_MT6761_Tecno_V3(Auth) Brand : Tecno Model : 0_MT6761_Tecno_V3(Auth) Exe Name : TFM Tool Pro MTK v1.9.4 Exe Version : v1.9.4 Action : MDM Remove (Tecno/Infinix) Checking account info... UserName: -----511-- Expire Date: 2025-08-29 10:16:07 Balance: 5.00 USD Downloading da file...Ok Waiting for usb device... Detected MediaTek PreLoader USB VCOM (Android) (COM15) Driver Details Driver MF MediaTek Inc. Driver Name wdm_usb Driver Version 3.0.1504.0 Driver Date 1-22-2015 Connecting to brom... Successfully connected with brom! Brom Information... Chip : MT6761 Hw Code : 0x717 Meid : dcda14c65b087bf0c5e91cbcc6cab858 Downloading resource1...Ok Initializing resource1...Ok Downloading resource2...Ok Initializing resource2... Trying alternate method... Initializing exploit data...Ok Downloading first da... Transferring control to DA...Ok Syncing 1st DA sync char...Ok Syncing 2nd DA sync char...Ok 1st da successfully sended Downloading second da...Ok Usb Speed Status : High-Speed Checking compatible driver...Ok Operation agreement...Ok Using the iit auth.. Requesting for authentication...Ok Writing remote data...Ok DA Information.... Boot information... Chip ID : 0x200ca018a000717 Storage : EMMC Boot1 : 4.00MB Boot1 : 4.00MB Rpmb : 4.00MB Userarea : 58.25GB MLC : 0x1 SLC : 0x1 EOL : 0x1 LCycle : 0x0 CID : 129185736687597140514102899912136635439 MFRID : 0xd6 Vendor : Unknown Card BGA : Unknown OEMID : 0x0 Product : MMC64G:4d4d43363447 Revision : 5.1 Card SN : 0f542f78 MFDate : 5/2023 Reading partition....Ok Removing MDM...Ok Rebooting phone...Ok Operation Finished! Elasped Time : [00:min:10:sec] Saving logs... Operation/Work ID: 4083397 |
The Following User Says Thank You to Waseem-y For This Useful Post: |
10-07-2023, 12:02 | #304 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2466934 Status: Offline Thanks Meter: 54 | Job Time : Oct Sat 2023 10:10:30 Operation/Work ID: 4138607 Brand : Tecno Model : KI5K - Spark 10c Exe Name : TFM Tool Pro SPD V1.5.0 Exe Version : v1.5.0 Action : Unlock Bootloader Checking account info... UserName: AM19x Expire Date: 2024-09-10 14:57:06 Balance: 0.00 USD Retriving data...Ok Power Off Your Device & wait 10-15 seconds.... Press and hold BootKey ( Both Vol Or Vol+ Or Vol- ) As Device Base. Insert cable in device! Waiting for usb device... Detected: SPRD U2S Diag (COM65) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.20.42.134 Driver Date 10-14-2020 Initializing connection...Ok Checking baud...SPRD3 Sending fdl...Ok Waiting for usb device... Detected: SPRD U2S Diag (COM65) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.20.42.134 Driver Date 10-14-2020 Kick fdl...Spreadtrum Boot Block version 1.1 Sending second loader...Ok Authentication needed! Generating blob key...Ok Writing blob key...Failed Using Second Server... Generating blob key...Ok Writing blob key...Ok Resetting MDM Lock...Ok Note: Do, Factory Reset from recovery mode .Otherwise, you can use factory reset in diag mode Rebooting phone... Reboot done... Operation Finished! Elasped Time : [00:min:08:sec] Saving logs... |
The Following User Says Thank You to AM19x For This Useful Post: |
10-13-2023, 16:02 | #305 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | X669 - Hot 30i FRP This is amazing! No other tool can. I know because I tried. I have been suffering since this morning, when I realized that I have TFM-tool:-) Brand : Infinix Model : X669 - Hot 30i Exe Name : TFM Tool Pro SPD V1.5.0 Exe Version : v1.5.0 Action : Reset FRP Checking account info... UserName: Mark1 Expire Date: 2024-05-20 22:31:06 Balance: 5.00 USD Retriving data...Ok Power Off Your Device & wait 10-15 seconds.... Press and hold BootKey ( Both Vol Or Vol+ Or Vol- ) As Device Base. Insert cable in device! Waiting for usb device... Detected: SPRD U2S Diag (COM210) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.20.42.138 Driver Date 8-2-2021 Initializing connection...Ok Checking baud...SPRD3 Sending fdl...Ok Waiting for usb device... Detected: SPRD U2S Diag (COM210) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.20.42.138 Driver Date 8-2-2021 Kick fdl...Spreadtrum Boot Block version 1.1 Sending second loader...Ok Authentication needed! Generating blob key...Ok Writing blob key...Failed Using Second Server... Generating blob key...Ok Writing blob key...Ok FRP Resetting...Done! Rebooting phone... Reboot done... Operation Finished! Elasped Time : [00:min:07:sec] Saving logs... Operation/Work ID: 4307489 Thanks! |
The Following User Says Thank You to Pufi164 For This Useful Post: |
02-18-2024, 13:13 | #307 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | Infinix HOT 40 Pro MDM Done. Code: Brand : Infinix Model : 0_MT6789_Infinix_V1(Auth) Exe Name : TFM Tool Pro MTK v2.0.1 Exe Version : v2.0.1 Action : MDM Remove (Tecno/Infinix) Checking account info... UserName: xxxxxx Expire Date: 2024-09-27 10:12:08 Balance: xxxx USD Downloading da file...Ok Waiting for usb device... Detected MediaTek PreLoader USB VCOM (Android) (COM9) Driver Details Driver MF MediaTek Inc. Driver Name wdm_usb Driver Version 3.0.1504.0 Driver Date 1-22-2015 Connecting to brom... Successfully connected with brom! Brom Information... Chip : MT6789 Hw Code : 0x1208 Meid : b5ee6101832d76a36b5852bdda8510e2 Downloading first da... Transferring control to DA...Ok Syncing 1st DA sync char...Ok 1st da successfully sended Downloading second da...Ok Usb Speed Status : High-Speed Operation agreement...Ok Using the iit auth.. Requesting for authentication...Ok Writing remote data...Ok DA Information.... battery_voltage : 4336 block_size : 0x1000 id : 65554653322E325F323536000000000000000000 lua0_size : 0x400000 lua1_size : 0x400000 lua2_size : 0x3bad800000 lua3_size : 0 product_id : ram_size : 0x200000000 random_id : 99904f5a3c862e3a58530692050edd3f storage : UFS version : 1.2 build : Sep 4 2023:13:18:25 da_version : 2021 version : 1.0 Reading partition....Ok Removing MDM...Ok Rebooting phone...Ok Operation Finished! Elasped Time : [00:min:11:sec] Saving logs... Operation/Work ID: 8278267 |
The Following User Says Thank You to .::Gsm-Play::. For This Useful Post: |
03-01-2024, 00:03 | #308 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Caracas, Venezuela
Member: 2527159 Status: Offline Thanks Meter: 35 | Tecno Spark 10C KI5k Successful downgrade and repair phone had v560 firmware, i couldn't repair imeis because of that so downgraded to FW ver.554, phone started with imei 0000000000 and successfully repaired imeis Brand : Tecno Model : KI5K-Spark 10c Exe Name : TFM Tool Pro SPD V1.8.0 Exe Version : v1.8.0 Action : Write Security Checking account info... UserName: Expire Date: 2025-03-01 17:19:06 Balance: 0.00 USD Power Off Your Device & wait 10-15 seconds.... Press and hold BootKey ( Both Vol Or Vol+ Or Vol- ) As Device Base. Insert cable in device! Waiting for usb device... Detected: SPRD U2S Diag (COM117) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.20.42.134 Driver Date 10-14-2020 Initializing connection...Ok Checking baud...SPRD3 Sending fdl...Ok Waiting for usb device... Detected: SPRD U2S Diag (COM117) Driver Details Driver MF UNISOC Communications Inc. Driver Name sprdvcom Driver Version 4.20.42.134 Driver Date 10-14-2020 Kick fdl...Spreadtrum Boot Block version 1.1 Sending second loader...Ok Authentication needed! Generating blob key...Ok Writing blob key...Failed Using Second Server... Generating blob key...Ok Writing blob key...Ok Reading partition...Ok Reading security information... IMEI 1 : 000000000000000 IMEI 2 : 000000000000000 New security details... IMEI 1 : 353691171xxxxxx IMEI 2 : 353691171xxxxxx Writing security information...Ok Security information written successfully. Note: Do, Factory Reset from recovery mode .Otherwise, you can use factory reset in diag mode Rebooting phone... Reboot done... Operation Finished! Elasped Time : [00:min:11:sec] Saving logs... Operation/Work ID: 8686731 |
The Following User Says Thank You to JLLE21 For This Useful Post: |
