The Market Feed Back Write here your feedback and your Comments about buyers, sellers or Product Feed Back, Read Carefully The Related Rules for this Section. |
06-18-2010, 05:22 | #1 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | UB is the best team but how they forget to think.............? ============================================= Some model doesn't support from F-Bus. If we try from F-but than it shows "Terminate with error: No available for this ID: Probably Bad Cable etc" Cable is Ok probably boot loader problem. In this case, they have to give us option to erase USB . But, there is no option. 2. They do not give us choose and flash using USB ====================================== As previously, we can't choose the file say MCU, PPM and Image to flash USB mood. But, we need product code. 3. We can only flash using Product code using DEAD USB mood =============================================== OK, this is ok but let us know wehre is "signature bin" file in support. Not have any signature.bin file in support. Without signature bin, We can't flash using DEAD USB mood. see the picture :- Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu BR [email protected] sairam_mobile @hotmail.com |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
06-19-2010, 12:22 | #2 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | More Over......... 4. UB must depend on Phonex file, if we want to flash USB ============================================ There is only signature.bin file in Phonex. But, I did not see any signature.bin file with MCU, PPM, Image etc in the support. Phonex files are too big to download. If we want to download the files upper version than the product code, then comes the problem of signature bin file. And as you know, in DEAD USB mood, without this file, even "Flash" doesn't high light. 5. RPL Backup and Restore Function =========================== Sometimes we need to backup alive mobile's RPL and later restore it back to phone. Where this function in UB??? BR |
06-19-2010, 12:48 | #3 (permalink) |
Freak Poster Join Date: Dec 2006 Location: location,location....
Member: 411486 Status: Offline Thanks Meter: 68 | You have a good point in what you are saying,but the most important thing is the f-bus flashing,not the usb.The old problem with bootloader id must be solved.I have alot Nokia boxes and i say this UB is one of my first choices so pls work on this UB Team.....we beg you and request this fix. |
06-25-2010, 10:50 | #4 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Another Big update-USB Flashing Achivement of UB I have install Windows XP and MS Net firmwarok 3.5 in my computer for Universal Box. I can't flash choosing files according my will. And If I choose file then there are no signature bin file in the UB site. SO, I download of Phonex file and I put it inside UB. while I hit the button, it searches something for 5 minutes and says "The procedure entry point _ftol2_sse could not be located in the dynamic link library msvcrt.dll" see the picture link:- Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu and as soon as it shows another error screen and says "Terminate with error : Framework: Internal error occurred for configuration. Details : MS XML parser 6.0 is not installed (00010123)" See the picture link: Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu Then, I see in the control panel, the MX XML parcer 6.0 is present there. Again I downloaded it from:- Download details: MSXML 6.0 SP1 Then, I try to install it and it says "higher version already present" See the picture link:- Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu Now, tell me the team what is this problem??? Team we need our previous USB Flashing Button. After bug fix then we need latest version. Thankx BR [email protected] |
06-27-2010, 10:12 | #5 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | The procedure entry point _ftol2_sse could not be located in the dynamic link library After long search, I have found about the solution which mentioned above. The solution is here:- How To Fix Msvcrt.dll Errors? at Instant Registry Fixes BR [email protected] |
06-27-2010, 11:00 | #6 (permalink) | |||||
No Life Poster Join Date: Jun 2004 Age: 48
Member: 68982 Status: Offline Thanks Meter: 17,853 | Quote:
1: certificate erasing /writing is not allowed by usb because only uart (FBUS) loaders have this function. So usb loaders are supporting only flashing.. 2: We've disabled this function because many users selected wrong files and phones gone dead. Now you can't make any mistake, you should select product code (you can check the name also of the selected code) and your phone will be 100% working. What is the difference between the two options? In this case you should know just the region EURO3, etc and select only this. In "old" case it was more complicated, if you was tired, you've selected wrong files, or not all files and then phone was dead, restarted after few sec, only white screen... 3: usb flashing is supported also from normal mode, so not only from dead mode.. Quote:
5: BB5/maintenance tab. There is read certs -> this will read the npc, ccc, hwc,... certificates and you can restore them any time with restore certificates button. Quote:
Yes, this will come in coming update, but there are always other jobs before this. I hope you can understand me, and you like our work Quote:
The Following User Says Thank You to universalbox For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
