The Market Feed Back Write here your feedback and your Comments about buyers, sellers or Product Feed Back, Read Carefully The Related Rules for this Section. |
05-13-2013, 09:42 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: under the philippine deep
Member: 1766158 Status: Offline Sonork: 1618330 Thanks Meter: 24 | What boxes support windows 7 64 bit? atm I have tried ATF only for my windows 7 64 bit but haven't tried flashing with it. Thanks. |
05-13-2013, 20:17 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | In my opinion there's no interest to run boxes software under W7 64bits. Keep this os for personal entertainment, and use a good old xp sp3 based pc to work. Many boxes run well under this os, even lgtool last version writes when you start software under w7 that it's made to work in xp. Don't mix everything. Anyway you can try one by one, and function by function but you'll face maybe more issues, and you won't be sure if it comes from win7 or soft itself. BR |
05-14-2013, 03:15 | #3 (permalink) |
Member: 1766158 Status: Offline Sonork: 1618330 Thanks Meter: 24 | yeah i know xp is preferrable but i had bought a laptop without a windows xp driver and sadly i cannot use it under xp sp3 (i tried twice) it runs but no drivers can be install even those compatible ones wont work. i have sold my desktop pc already and switched to this laptop (which runs on 64 bit) |
05-14-2013, 10:14 | #4 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | If you're experienced enough, make a double boot. Or buy a second hand old pc, I mainly work with a pentium m laptop with 2go ram, and that makes the trick... Or even something similar to the dell d620 (dual core) which is quite cheap now will work fine. |
05-14-2013, 12:12 | #5 (permalink) |
Member: 1766158 Status: Offline Sonork: 1618330 Thanks Meter: 24 | thanks for the suggestion though you havent read my post clearly, as i have said my laptop doesn't come with windows xp drivers, i know i can make a double boot (xp and 7) but the problem is that even though i install xp, i cannot make use of the laptop's hardware (no drivers at all) and i also have no plans of buying another pc. something just came up and i need to upgrade to 64 bit even though i donot like it. hope you get my point br, |
