Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools. |
08-05-2008, 16:16 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Help For Nokia N91 Key Pad Ic Where Can I Get N 91 Key Pad Ic In Mumbai (india ) Market I Am Not Getting These Ics In Regular Sources |
The Following 3 Users Say Thank You to omkarvitekar For This Useful Post: |
08-05-2008, 18:29 | #2 (permalink) |
Junior Member Join Date: Sep 2006
Member: 346219 Status: Offline Thanks Meter: 2 | If There are nothing the ic u want, u can use jumper trick maybe. Just remove the ic and jumper both side foot ic. n the foot in the midlle forgetted. that's all I hope can help Regards, Agslove |
The Following User Says Thank You to agslove For This Useful Post: |
nokia 6280 numeric key pad ic print is ok but frornt panel keypad ic print is broken | Matwala | Nokia Hardware & Hardware Repair | 2 | 07-22-2012 08:09 |
nokia 6600 one key pad ic print damage need help | Hitesh manocha | Nokia Hardware & Hardware Repair | 0 | 10-14-2009 12:06 |
w550i,the 2,8,# not working.. changed 3 key pad ic,, key pad noww what to do??? | broken_rules | Sony Ericsson Hardware Repair | 2 | 03-20-2009 15:44 |
nokia 6300 key pads ic | sudais_rizwan | Nokia Hardware & Hardware Repair | 3 | 06-06-2008 03:26 |
i need help for Nokia N91 all key not-work | chronic | Nokia Hardware & Hardware Repair | 2 | 12-23-2007 16:08 |
