Alcatel & TCL Old Models Alcatel Old models like HD-x, HE-x , also BE Series like BE1, BE2 ,, BEx ext. here also located all TCL models threads like e777,d308,d868 & d818 models. |
11-07-2000, 15:56 | #1 (permalink) |
Freak Poster Join Date: Nov 2000
Member: 2515 Status: Offline Thanks Meter: 4 | Pleas, I need flash 16B 2MB I played with my AOT easy db ver. 16B, 2MB fujitsu. Then I want to write my origin flash back but it doesn't work. Andromeda 4.8 didn't read all flash or something like that. My backup file is shorter of 165 bytes. I tryed: www.afilip.kgb.cz -the best Alcatel's unlock site www.gsm.dir.bg/bg/SOFTWARE.net -good site gsm.service.virtualave.net mobile.box.sk/manufacture.php3 -soft mobilfunkdatenbank.de/tachharms/deliverse_c.htm www.multicentro.com/movihome/flash.htm -flashes www.maddog.co.yu/gsm -soft www.easy.nu/~phonesoft -flashes,soft But flash doesn't work or I cann't reach them (download). Pleas, if you could, send me flash from 16B 2MB. Size of this file must be (extracted) 2097152. [email protected], Igor (MRU), Brno, CZECH REP., Central Europe P.S. Plural of flash is flashs or flashes? |
11-07-2000, 22:33 | #2 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Czech Republic
Member: 1993 Status: Offline Thanks Meter: 94 | Cau zkus to na http://router.klubi.bytom.pik-net.pl/~piotr/index.html Eerchant (16A by do toho měla jít) |
11-08-2000, 01:46 | #3 (permalink) |
Freak Poster Join Date: Aug 2000 Age: 55
Member: 1920 Status: Offline Thanks Meter: 3 | WHEN YOU WANT FLASH THE 2MB ALCATEL PHONE FOR THE FIRST TIME ,, TRY TO FLASH IT MORE THE 20 TIMES BY Andromeda 4.8 YOU WILL SEE THE FLASHING LIKE THIS:- FIRST TIME 10% SECOND TIME 13% TER 18% ....... ........ AFTER 20 TIMES 100% AFTER THAT ITS WORK 100% READ&WRITE FORM THE FIRST TIME,,, TESTED BY ME ... |
11-08-2000, 14:40 | #6 (permalink) |
Member: 2515 Status: Offline Thanks Meter: 4 | I thanks to Eerchant for good link. I will try the flash from this site and i will tell you more. I also wrote to same people to send me flash but I cann't acces my e-mail at www.email.cz . If they send me some files, I will put them on my web. I will say it's IP later. (I don't know it just now). To your advice (or advise): It is very interesting to write 20 times the same flash. I will try it. |
11-08-2000, 16:17 | #7 (permalink) |
Freak Poster Join Date: Oct 2000 Location: Kosice, Slovakia
Member: 2369 Status: Offline Thanks Meter: 0 | Hi ! I am only looking to this forum, how many Czech and Slovak unlockers are there..... I can send U 2Mb flash but 16C ... Correct language file is on Ales Filip site. cz2mb.bin. So can U tell me where I can download andromeda software which support 2Mb flash chips? Exactly chips name is ST... My version of andromeda does not work... Please help me... I have got working BE1srv but I have not andromeda... Zlom vaz ! Thanx QIDO [email protected] ------------------ Slovak GSM group |
11-09-2000, 09:23 | #8 (permalink) |
Member: 2515 Status: Offline Thanks Meter: 4 | Hi quido! I think Andromeda 4.8 support 2MB chips. try http://www.afilip.kgb.cz . But I also thing I tryed it. I have this versions of Andromeda (4.0 4.1 4.8 5.0 5.0crk 5.4) but working is only 4.8 (maybe +4.0); On my "Useful link is Andromeda 4.9 but I didn't try it. Igor, MRU |
11-09-2000, 10:54 | #9 (permalink) |
Member: 2369 Status: Offline Thanks Meter: 0 | Hi MRU ! Thanx for your tips, but... Andromeda 4.8 and 4.9 is 100% working software. Ive got tested Andromeda 4.9. Andromeda may support 2Mb chips but ST chips are probably not supported. All programs are downloaded from Afilip.kgb.cz. Andromeda 4.9 is from another site... I need patch for 2Mb ST chips... Please help me Anyone... QIDO [email protected] ------------------ Slovak GSM group |
11-10-2000, 23:17 | #10 (permalink) |
Member: 2515 Status: Offline Thanks Meter: 4 | Hi qido! I don't know ST chip (only Atari ST), but when I execute be1flsh.exe form Ales's site I can see that it supports AMD FUJI and ST chips. But I don't know if it supports 2MB chips. So if you want to tri it - Alcatel BE1 flash v 6.4 Igor MRU |
11-11-2000, 18:52 | #11 (permalink) |
Member: 2369 Status: Offline Thanks Meter: 0 | Hi mru ! Many thanx for your research,, but this program is not working 100% If I need download flash from phone, program doawnload only 16 kB of any data and then halt... I need something fully compatibile with 2mB ST chips... QIDO [email protected] ------------------ Slovak GSM group |
11-11-2000, 21:07 | #12 (permalink) |
Junior Member Join Date: May 2000 Location: Germany
Member: 1370 Status: Offline Thanks Meter: 0 | Hi all, at first to MRU I do have some 16B, but be aware 16B ist not 16B ! Tell me the last !! digit (15) of your IMEI and i will see if i can help you. Hi QIDO with the ST-Problem There is a workaround for your problem. Take Andromeda 4.1 and: 1.Connect to a Alcatel OTE DB with internal AMD or FUJ. 2.Change then the connected mobile to the damaged one before you continue. And you will the it works. May be someone can help me with a working sheme for USPU 4.35 and Alcatel OTE DB ??? And at last i need a off-cable solution for Trium Astral 140. |
11-13-2000, 22:22 | #15 (permalink) |
Member: 2515 Status: Offline Thanks Meter: 4 | Hi people, Gorgonzola, Slawek, Honzahonza@... and other people that helped me! Maybe I have the reason of my problem with my 16B 2MB. I tried 13 flashes of 2MB's AOT db and only 1 works correctly (6x16B, 3x16A, 1x162, 3x163). I have 1 flash of 162 and it works for the first time. I have 6 flashes of 16B and no one works! (...every is of 2MB length) So i think that my 16B ISN'T 16B version. This phone was reparing in service. Maybe they changed the cover (housing) of the phone. Maybe the hardware of the phone is 162 version. How can I find out this? So, what I need now? Please, tell me how can I change language in ver. 162 2MB. I tried to do it with BE1srv 12.3 (I had to replace '162' to '16B' in flash(162) on both 2 places) but the phone was writting flam (bad strings) after proces. Alcatel DB ****er 2.0 eng was same. Please, which soft works on ver. 162 ? Can anybody send me another flash from 162 2MB? Thank you for help! Igor MRU, CZECH REP. P.S. today I updated firm sites: http://www.beatman.cz and also today I typed my (first) own web site: http://www.web-city.cz/~charvat/i/i.html |
pleas i need flash for alcatel th4 anu one can help me | griffn | Multi-Box | 1 | 08-30-2009 17:46 |
pleas i need flash ku990 | raoul plus | Multi-Box | 4 | 04-12-2009 19:59 |
pleas freinds need flash files for 6265(mt-ufs) | day@walker | Nokia CDMA | 0 | 04-16-2007 01:35 |
pleas i need flash x105 | pinco | Trident/AGERE Platform | 5 | 06-16-2005 14:12 |
Pleas help,need flash for gd87A39 | artgsm1 | Panasonic | 2 | 07-30-2003 06:55 |
