Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
02-21-2010, 11:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: jharkhand jamshedpur INDIA Age: 38
Member: 226587 Status: Offline Sonork: 100.1603781 Thanks Meter: 352 | Samsung CDMA test commands 1, * 759 # 813.58 thousand Into the test mode, all commands can be ended by the # command: Command to display the explanation 01 Suspend Suspension: Some command execution before the need to run this command 02 out of test into the test state, the shutdown does not work Kin 07 carrier _disibledevent = 218 (7) Battery capacity data (factory setting) 52 h / w = 47f.04 version number 53 lock cod: 0000 Display the lock code 57 mic unmute the microphone opening 58 mic mute the microphone off 59 sio mode1 serial output mode, in order to 1 through the bottom of the connectors and computer communications 67 rd batt vai reading of the battery parameters 68 stby batt-XXX battery data sampling, with the voltage change 69 talk batt-XXX battery data sampling, with the voltage change, as the 70 command reference 70 wr batt-XXX power to read and write data on 000-255, with STO storage, low-voltage alarm to adjust 71 cd txagc-XXX transmit power level xxx = 000-511, with STO storage, value the greater the greater the firing battery, do not launch a long-current 72 cd txagc-XXX enrichment xxx = 000-255, with the STO Storage 74 Tx RAS [xx] xxx transmit power levels [01-16] xxx = 000-555, the first line shows the corresponding dB values 75 rd rssi display field strength value of about 50 normal 76 wd rssi value of field intensity is stored 77 rd temp reading of battery temperature 79 buzzer on ring-opened 80 buzzer off ringing off 81 pcm loop on pcm codec loop open 82 pcm loop off pcm codec loop closed 85 sperker on the handset to open 86 speaker off the handset off 2, standby screen, press M-6-* can enter the system program, the password is 000000 3, standby screen, press M-9-0 to enter a user lock, if not set-off, the initial user lock is 0000, you can set up access to the Internet 4, standby screen, press M-8-* into the test screen, the password is 1235806 b.r yuvi |
The Following 2 Users Say Thank You to Yuvi For This Useful Post: |
05-18-2010, 23:21 | #3 (permalink) |
Junior Member Join Date: May 2010
Member: 1306602 Status: Offline Thanks Meter: 0 | Manual FTM These commands do work. I messed up though. I went a little too far and entered command 121, quickboot mode, When I enabled quickboot the phone still boots and is on but the firmware never loads so I can't do anything else at that point. Does anyone here know how i can fix this? Do Samsungs have a way to hard reset? I don't know if hard reset is possible because I can't access anything, no command, no buttons, nothing. Maybe PST? I have PSTlite but have never used it. Any help would be greatly appreciated. |
need information,CDMA Test Call,Samsung TS200 | fove yerenov | Various CDMA/TDMA Cell Phones | 1 | 02-16-2005 08:18 |
Vxxx manual test commands | akalias | Motorola P2k | 0 | 12-07-2004 17:38 |
V70 Service Manual, V6X Test Command DOC for exchange. | Mike Ho | Motorola P2k | 0 | 04-27-2002 01:33 |
