07-20-2004, 14:31 | #1 (permalink) |
Junior Member Join Date: Aug 2003 Location: india Age: 42
Member: 36794 Status: Offline Thanks Meter: 1 | 2100 auto charging i got 2100 auto charging .when i connect charger then it show charging but when i disconnect charger it show charging again but after some times it shows charging not done. i have changed few resistances near to charging IC and changed charging IC also. but its in the same problem what should i do please help me its urgent for me........... thanks avtar |
08-12-2004, 02:26 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | hello friends do u get any idea regarding this? I suspect there may be a print break near chrg ic compare with good one im a serv tech from india. [email protected] |
08-13-2004, 14:18 | #5 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | hi, sometimes it may software problem, did u flash phone. if not fullflash it with good flash file. this may solve ur problem. regards |
09-06-2004, 02:59 | #8 (permalink) |
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | In 3310 It Is Solved By Shorting Two Points Near Charging Ic .im Experianced In So Many Cases. 2100 Also Uses Same Ch:ic So I Suspect This May Also A Break !!!! So Compare With A Working Set Try!! |
samsung T100 auto charging whith out connect charger set is auto charging | shani72 | Samsung Hardware Repair | 0 | 02-16-2009 13:22 |
need 2100 auto charging solition | faju | Nokia Hardware & Hardware Repair | 2 | 12-16-2008 17:33 |
2100 auto charging | shinod | Nokia Hardware & Hardware Repair | 3 | 04-29-2005 09:54 |
