03-10-2002, 02:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | 3210 COntact Service problem i got a nokia 3210 v4.02 , and it had a contact service problem before . When i resetted mobile using nokia tool the contact service problem faded away . And now mobile seems to work fine , but it isnt ! . Right now the mobile is working 100% , i can recive and make calls , but after a while i cannot make any calls and when i type *#06# it displays a corrupted IMEI number . The imei is 448903200284698 but when it decides to corrupt it will display imei 002?37::34245 or something like that . I didnt flash phone yet cause i dont have a flasher cable . If i will flash it will it solve this problem or i must buy a eeprom reader/writer to solve it ? cause it seems like eeprom is corrupted ! . thx |
03-10-2002, 12:23 | #2 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | HI again Problem of contact service re-surfaced again . when i insert a data cable phone switched on and works great for a couple of hours or minutes . Flashing the mobile will help or ? thanks |
03-10-2002, 15:32 | #3 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | Hi mp3hot! I think flashing will not help because imei number is stored in physical eeprom of 3210. You should write clean eeprom with eeprom programmer and then calculate faid & imei data. That will solve your problem. BufferMess |
03-10-2002, 20:33 | #4 (permalink) | |
Member: 7844 Status: Offline Thanks Meter: 182 | Quote:
is this the right eeprom programmer to use ? SMD EEPROM programmer with SOIC Clips on www.ucables.com ??? thx | |
03-11-2002, 21:30 | #5 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Hungary Age: 49
Member: 6472 Status: Offline Thanks Meter: 1 | Sometimes works good sometimes not hi, If your phone work good again when use nokiatool (or make some pressure with the connector to the phone's mainboard)). And after a while CS again, and IMEI is corrupted, Hmm, weill, if you have got a soft problem in the eeprom IMEI area you wouldnt get a working phone without reprograming. Just thinking : if some bytes overwritten in the eeprom caused by X-ray or electomagnetic field power or some Hell's thing, so you never get a working phone again withot reprogramming, These bytes has no chance to rewrite itself to origi states!! More likely my mate: You have an old 4.x ver 3210. So the contacts beetwin the cobba chip and the phe's matherboard is not perfect, and as well somtimes the Cobba-ID also not correct, and so the IMEI programming data not perfect, and last you got a CS with incorrect IMEI!!! When you connect an mbus cabel to use nokiatool or etc. you made some pressur and the cobba contact renew for a while , but not for ever Rehot your cobba chip with a hot air gun and a good flux. OR play wit until get a signal and sell it quickly) |
03-12-2002, 14:48 | #6 (permalink) |
Member: 9856 Status: Offline Thanks Meter: 2 | Pony Programmer! I don`t know whether SMD Programmer with SOIC Clips is good or not because I never used it. I always use Pony Programmer and I am quite satisfied with it. BufferMess |
03-17-2002, 12:56 | #7 (permalink) | |
Member: 7844 Status: Offline Thanks Meter: 182 | Re: Sometimes works good sometimes not Quote:
is this the cobba chip i must re-flow ? on : http://www.inside-gsm.com/Nokia/Noki...ion_nokia.html code number 14 ??? thanks | |
3210 CONTACT SERVICE Problem | phylon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-19-2007 16:17 |
3210 CONTACT SERVICE | mudboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-22-2001 02:54 |
3210 Contact service | Unlocker AL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-20-2001 18:09 |
3210 Contact Service !!?? | ceko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-12-2001 04:15 |
3210 Contact Service | king76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-2000 16:07 |
