12-14-2000, 20:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Age: 55
Member: 1246 Status: Offline Thanks Meter: 25 | 3210 v3.10 with 4 locks Tried to unlock,3,2,4 and 1 trick but with no luch. any ideas? regards anna |
12-18-2000, 22:20 | #2 (permalink) |
Member: 1246 Status: Offline Thanks Meter: 25 | Where are u men Is my problem too easy that no one want to spend some minutes in solving ,or it is too difficult that anyone has ideas? P.S I have had the same problem before,but with version 5,36 and I solved it,but with this version caoldnīt. |
12-19-2000, 00:06 | #4 (permalink) |
Member: 1246 Status: Offline Thanks Meter: 25 | Just connect a wire to pin 5 on eeprom read the phone by nokia tool(b.34) Hold the wire and read the phone again and u should see funny imei on lock 3 press unlock 4-5 times free the wire from ur hand and on lock 3 press unlock,and this lock shoud be open now. Repeat the same procedure with locks 2,4 and 1. phone should be unlocked. tested by me 100% working. regards anna |
12-19-2000, 00:47 | #5 (permalink) | |
Freak Poster Join Date: Nov 2000 Location: Croatia Age: 47
Member: 2466 Status: Offline Thanks Meter: 10 | This solution not working! Quote:
12-19-2000, 01:01 | #6 (permalink) |
Member: 1246 Status: Offline Thanks Meter: 25 | Did u try it? Did u make the same steps? Did u see funny IMEI by touching the wire from pin 5? Did u ground urself well? TESTED BY ME SEVERAL TIMES AND IT IS 100% WORKING. TO ALL FORUM MEMBERS WHO TESTED THIS PLEASE CONFIRM. REGARDS ANNA |
12-19-2000, 03:12 | #7 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Hi all Yes Anna i can confirm it works but i use needle for pin 5, less chance of lifting 10k buffer resister these are a pig to get back right but your unlock procedure is ok Regards charlie |
12-19-2000, 17:52 | #8 (permalink) | |
Junior Member Join Date: Dec 2000 Location: Malaysia
Member: 2849 Status: Offline Thanks Meter: 0 | Howcome I touched pin 5 it doesn't show funny imei ? I'm not even sure if i've touch the correct pin. can anyone please show me which is the correct pin or eeprom. Quote:
12-21-2000, 00:14 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2000 Location: mobile Age: 55
Member: 2399 Status: Offline Thanks Meter: 747 | Anna, your a darling, if your solution works re pin 5 and v5.36...we all will be much more confident in ourselves.. Anyway, pin 5 is the first pin on left hand side when looking at fone correct way up and chip facing u.... regards |
12-22-2000, 16:46 | #11 (permalink) | |
Member: 2849 Status: Offline Thanks Meter: 0 | Yes I've got it !! A thousand Thanks to Anna and Mobileman Quote:
How can I unlock my 3210 V3.10? | Zoio | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-16-2009 14:19 |
Nokia 3330 v3.12 with 4 locks with dejan not result | CHATAR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 11-09-2001 01:03 |
3210 v5.01 all 4 locks closed!!! | trafix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-18-2001 03:24 |
3210 v3.10 | zlephone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-02-2001 04:37 |
3210-EEPROM OK-ALL 4 LOCKS closed showing content EEEEE / FFFF | JohnDoe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-02-2000 21:04 |
