01-27-2002, 15:48 | #2 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | Hi! Plz specify the adress where you wrote to..<br />If it was the correct adress, check partial and try to unlock again... If it was wrong adress, and you made a backup, then write backup... If you don't have backup, then find one on the net... try schwantz site... <img src="smile.gif" border="0"> C ya! |
01-28-2002, 00:14 | #3 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Zagreb, Croatia Age: 41
Member: 7558 Status: Offline Sonork: 100.94170 Thanks Meter: 6 | the best softvare is ****Koci nokia unlocker**** ............for newbie .........................<br />(start adrese ,boot louder )forget only press unlock <br />------------------------------------------------- <br /> ***[email protected]*** ***GSMsolution*** |
02-09-2002, 16:52 | #6 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Disneyland Age: 47
Member: 8329 Status: Offline Thanks Meter: 6 | ...or Flash it with Full Flash from a Good Backup from Another Phone with same MCU+PPM. (Start Address 0020000 - 0040000) and calculate FAID if necessary... BR <img src="wink.gif" border="0"> <FONT COLOR="#ffff00" SIZE="1">[ 09 February 2002 16:56: Message edited by: Chryse ]</font> |
02-10-2002, 11:06 | #7 (permalink) |
Junior Member Join Date: Dec 2001 Location: London,England
Member: 8033 Status: Offline Thanks Meter: 0 | I have a 3210 V6 that is dead too.<br />When i got the phone it was saying contact service,I tried to re flash it but to no avail. I have today managed to get another V6 so i made a full backup from 00200000 to 00400000 OK. Then i tried to flash it to the dead phone.<br />All seems OK to start with but the erasing flash is Succesful then dark lemming starts to write to flash, It write 5% or from 00200000 to 0021C000 then bombs out with writing to flash error. if i start the flash at 00218000 it will run past 0021C000 but again only till 5%. I have had this problem before on a Downloaded full flash but assumed it was that full flash was damaged. <br />But this new one is what i just created off of another phone. Anyone got any ideas? |
02-10-2002, 11:58 | #9 (permalink) |
Member: 8033 Status: Offline Thanks Meter: 0 | Hi Chryse <img src="smile.gif" border="0"> ,<br />I have tried every boot loader and flash loader.<br />It appears that i can use any boot loader and normal or intel16 flash loaders but all combinations i try give same results. the PC is a P3400 128Mb running Win98. I am just about to give up on the phone. |
02-10-2002, 12:13 | #10 (permalink) |
Member: 8329 Status: Offline Thanks Meter: 6 | Do you have Dejan Box 105... Try it...its better but if u don't have, try all minor troubleshooting... like connectors check if its connecting properly or check battery... it should be fully charge to avoid bombing out during flashing...etc. hope this can help... br <img src="rolleyes.gif" border="0"> |
02-10-2002, 18:21 | #11 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Iloilo City, The Philippines
Member: 8396 Status: Offline Thanks Meter: 2 | The big problem with flashing 3210s is that most connectors do not fit well. I have tried several but none really fits well. This is the main culprit in events like incomplete backup and writing. I guess nokia designed the fone to be used with a "caddy" for servicing. One thing you could do is to use flashers like Rolis or Ucables if you have them, and try not to move the fone while reading/writing. Perhaps holding the connector still will prevent another mishap. <img src="wink.gif" border="0"> |
02-10-2002, 18:39 | #12 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | some 3210 with atmel flash IC require different f_loader for reading and writing. dark shell only comes with the patched loader for reading so when you try to write it does it for a bit then stops or erases then stops.<br />if you cant find a good set of loaders, use rolis 4.77 to write the full flash files you have, this will set itself up automatically <img src="smile.gif" border="0"> |
02-10-2002, 19:52 | #13 (permalink) |
Member: 8033 Status: Offline Thanks Meter: 0 | Thanks for all the help, No i dont have a dejan box.<br />i can read from another phone the whole flash and can use other 3210s on mbus cable sections with noktool 035 and logo manager with no problems at all, so i dont think its a connector problem I will look into the last suggestion a bit more but the only place i have found to DL rollis 477 the zip file fails the CRC check.<br />If you know where i can get it from please tell me or else i will keep looking <img src="smile.gif" border="0"> Thanks again for all your help. |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
c975 v6.31 dead after unlock | usmartu | Smart-Clip | 1 | 07-25-2007 06:17 |
C975 Firmware R245_U_82.21.80I v6.36 dead after unlock | haxbox | Smart-Clip | 7 | 02-13-2007 19:04 |
