12-10-2000, 15:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2000 Location: Bratislava.SR
Member: 1630 Status: Offline Thanks Meter: 1 | 5110 all locked on EEEEE,FFFFF i have this phone CS repaired, now it displays insert simcard and locked on all locks; when i turn it on, it blinks one time ant then turns on; a service guy told me that it is not repairable!!! is it true? could somebody unlock it? |
12-12-2000, 00:52 | #2 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Philippines
Member: 1272 Status: Offline Thanks Meter: 3 | what version is that??? a lot of forumers here do fix those kinds of problems, but you need to bring the phone to them. if its an old 5110, ver 5.25 downwards, matbe nokiatool 034 can do th ejob |
12-13-2000, 03:51 | #4 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | Hi MDR, Were you able to solved this type of problem on 5110 ver 5.25 and lower using nokia tool 034 before? I got the same case ver 5.24, nokia tool can't simply eradicate the problem.I also tried KATOT's method without success, as what he said his method is good only for 3210v5.36 and 5110v5.29.. And since, I don't have the capability to reflash..The only solution I know is to change COBBA and use its pair of eeprom dump.. Any suggestions?!! Regards, neb |
12-21-2000, 03:09 | #6 (permalink) |
Member: 751 Status: Offline Thanks Meter: 19 | Hi, I also tried Dejan's flasher to solved all locks closed problem without success. You can fool the firmware from seing the actual locks condition on the eeprom by "partial flashing". But still "simcard is not accepted" eventhough, all locks can be seen as "open" after the process. Is it possible to solved this kind of problem by using dejan'flasher???.....Maybe on phones that flash emulates eeprom??? |
all lock fffff solution 1000%[for exchange] | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-01-2002 18:02 |
5110 all lock closed | gabor | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-29-2002 11:45 |
3330 all locks on EEEEE and FFFFFFFFF...solution??? | mashco | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 12-25-2001 19:58 |
Is there any solution for 3330 4 locks on EEEEE FFFFF??? | mashco | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 12-24-2001 14:04 |
all locked eeee,fffff on 5110 | vampire | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-20-2000 01:27 |
