04-11-2002, 01:23 | #1 (permalink) |
Crazy Poster Join Date: Jun 2000 Location: Lyon ,France
Member: 1654 Status: Offline Thanks Meter: 0 | 8210 ,signal drops . What do you think? Is it a hardware or software problem? Regards |
04-15-2002, 16:46 | #5 (permalink) |
Freak Poster Join Date: Feb 2002 Location: WORLD
Member: 9468 Status: Offline Thanks Meter: 0 | Open the fone and you will see a ***** pin which makes the connection to the pcb Make sure it is making a conection if not adjust it so that it is This may be your problem |
04-15-2002, 17:31 | #6 (permalink) |
Insane Poster Join Date: Apr 2001
Member: 3968 Status: Offline Thanks Meter: 0 | Hey guys, This case can possibly be both software and hardware. If the phone has a history of being dropped before, There's a strong possibility of the chip marked "HAGAR" was knocked off its solder from the board. If this is the case, be very careful and try to solder it back to the board. After this procedure, try re-calculating the flash authority ID and reset the phone via WINTESLA just to be sure. If it is a bug in the software, a little re-calculating of FAID and Reset might just do the job. I hope this helps. Regards, Muscleman |
8210 signal drop | bernardo | Nokia Hardware & Hardware Repair | 4 | 04-07-2004 23:54 |
help!!!!!!!8210 line drop | cskok2003 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-20-2003 13:07 |
Nokia 8210-8850 drops signal | tgsm | Nokia Hardware & Hardware Repair | 2 | 03-16-2003 20:27 |
8210 signal drop | AlQuds | Nokia Hardware & Hardware Repair | 5 | 08-15-2002 12:18 |
3210 no signal dropped???? | eureka8888 | Nokia Hardware & Hardware Repair | 3 | 08-25-2001 19:13 |
