11-09-2001, 08:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2001
Member: 6200 Status: Offline Sonork: 100.33330 Thanks Meter: 66 | CS problem in 3210.510, help needed Help needed please. Regards<br />bre786 |
11-09-2001, 13:25 | #2 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Hungary Age: 49
Member: 6472 Status: Offline Thanks Meter: 1 | Hi, man! You should send me that dump! I wiil try to help you! And you should flashed with partial to unlock your phone, because your eeprom area maybe is demaged. In this case (after flashing) your phone wont check this area.<br />I can recalc eeprom 1. and 2. chks and corrigate some bytes. <br />What is your dump's file? e2p, bin or hex? If you made e2p, you should cut out the pony header from the dump. You should have a copy wizh the origi chks too! |
11-09-2001, 14:21 | #4 (permalink) |
Member: 6200 Status: Offline Sonork: 100.33330 Thanks Meter: 66 | I can,t make any backup or write to any 3210 phone, do not know why. All other models works good with Dejan flasher V1.00b. I have a Universal All-07Programmer and used it for reading the eeprom bin file. I can also convert it to hex format. I will send this 24C128bin file to you tomorrow. Thanks with regards<br />bre786 |
11-12-2001, 00:44 | #5 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | Hi! That also happens to me. 3210v510. I cant read nor write to the fone. I found out that its a hardware fault. All I do to solved this problem is flashed the circuit with hotair especially the ccont chip. Then it sorted it out. Im sure that the fone has a cold solder on it. Thats why you cant read nor write to your fone. <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> |
11-12-2001, 09:43 | #6 (permalink) |
Member: 6472 Status: Offline Thanks Meter: 1 | Bre786! Hey, you sent me the flash file, but I need eeprom dump!!! not just a flash file... Guar refer eeprom not the flash! OK, all what I can do with your flash to check it with nfree 1.3. Send me the Dump also! |
11-15-2001, 17:57 | #8 (permalink) |
Member: 6200 Status: Offline Sonork: 100.33330 Thanks Meter: 66 | I am able to read the phone now and made full backup, the problem was wrong loader. Can,t flash back now , having erasing error after about 1 min of loading Dejan 1.00b. So the phone is dead now. regard<br />bre786 |
11-16-2001, 17:12 | #10 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Czech Republic
Member: 4246 Status: Offline Thanks Meter: 9 | Did you connect Vpp pin.<br />You have to use this pin for right connection.<br />Which Flash ID do you have?I will send you right f_loader. Regards |
11-21-2001, 17:55 | #12 (permalink) |
Member: 6200 Status: Offline Sonork: 100.33330 Thanks Meter: 66 | The connection is exactly as Dejan mentioned, a resistor of 100ohms from 2 diodes to pin 6VPP of 3210. The f_loader i,m using is '001f00c0' (atmel 16 - Atmel 49BV16X4B, size 16Mb), size is 5.44kb. Regards<br />bre786 |
How can i remove CS Problem In 6610i | digital_park | Cyclonebox | 3 | 01-21-2010 09:43 |
How can i remove CS Problem In 6610i | digital_park | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-21-2010 05:24 |
1200 cs problem in hardware or software | mobilecitycbk | Nokia Hardware & Hardware Repair | 1 | 01-27-2009 18:30 |
problem in flashing d830 help needed | alfox | UST Pro II | 4 | 10-26-2008 01:13 |
strange problem in 3210 | teefa | Nokia Hardware & Hardware Repair | 0 | 08-16-2004 20:24 |
