11-01-2001, 13:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Dejan flasher modified to run under Windows NT/2K I have uploaded a modified version of Dejan flasher that runs under Windows NT/2K to the following GSM groups: <a href="http://groups.yahoo.com/group/razvanelgsm/files/Nokia/Dejan2K.zip" target="_blank">http://groups.yahoo.com/group/razvanelgsm/files/Nokia/Dejan2K.zip</a><br /><a href="http://groups.yahoo.com/group/gsmhack-crew/files/Nokia/Dejan2K.zip" target="_blank">http://groups.yahoo.com/group/gsmhack-crew/files/Nokia/Dejan2K.zip</a><br /><a href="http://groups.yahoo.com/group/gsm_hacker/files/Nokia/Dejan2K.zip" target="_blank">http://groups.yahoo.com/group/gsm_hacker/files/Nokia/Dejan2K.zip</a><br /><a href="http://groups.yahoo.com/group/United_Gsmhacking/files/Dejan2K.zip" target="_blank">http://groups.yahoo.com/group/United_Gsmhacking/files/Dejan2K.zip</a> README.TXT: Dejan2K v1.00b by Dejan<br />modified to run under Windows NT/2K by Lead ///<br />USE AT YOUR OWN RISK!<br />--------------------------------------- This is a modified Dejan flasher, so the NK_FILES directory<br />does not have to be on the drive C.<br />Just unpack this archive and copy it to any directory you wish. 1. Login as Administrator (or another account with administrative privileges)<br />2. Copy UserPort.sys to C:\WINNT\SYSTEM32\DRIVERS<br />3. Run UserPort.exe<br />4. Click <Start><br />5. Click <Update><br />6. Run Dejan2K.bat<br /> (The reason is to use the COMMAND.COM shell instead of the CMD.EXE)<br /> Sometimes Windows writes a message "The system cannot open COM2..."<br /> In this case just press Cancel.<br />7. If in window-mode, switch to fullscreen pressing Alt-Enter.<br />8. DO WHAT YOU WANT<br />9. Click <Stop> in UserPort<br />10. Exit UserPort and delete UserPort.sys from the DRIVERS directory. Enjoy! With best regards,<br />Lead. |
11-05-2001, 14:47 | #3 (permalink) |
No Life Poster Join Date: Jul 2001 Location: EU
Member: 5423 Status: Offline Thanks Meter: 10 | Hi Lead!!!<br />Thanks for that but I caanīt running under WINNT<br />When I statrted I always get <br />"Starting up Dejan Nokia Flasher modified by Lead"<br />and blanking cursor<br />nothings happend<br />Please help me<br />I copied userport.sys inti system 32 run userport exe, press stat get Driver already inside<br />Click update,nothings happend, and running bat file get message abouve<br />PLease,please help me |
11-05-2001, 23:19 | #4 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | Hi ero!<br />Try starting COMMAND.COM first and then from the command-line start the flasher. Probably you should create a PIF-file defining maximum memory available to the flasher.<br />Just experiment! |
11-06-2001, 09:50 | #5 (permalink) |
Member: 5423 Status: Offline Thanks Meter: 10 | Hi Lead!<br />Thanks a lot my friend for answer, but I canīt running your tools.<br />I started command.com still before, and manual dejan2k.bat or dejan_8m, but always the same error<br />"Starting .......by Lead"<br />and cursor blinking<br />after that nothings happend<br />Regards |
"unable to access direct port I/O driver to run under Win NT/2000/XP" | SicilianBoy | SagMaster Team OLD Products | 6 | 11-15-2006 17:36 |
Help!! Can't Connect To Smartmoto Under Windows Me | venomhotboy | Smart-Clip | 2 | 11-11-2005 02:29 |
Dejan Flasher modified for Amd by GeorgeL. | Martino | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-08-2001 05:47 |
Dejan modified to run on P4 1.7GHz | Lead | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-22-2001 06:53 |
