06-01-2001, 11:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Uzhgorod, Ukraine Age: 47
Member: 3023 Status: Offline Thanks Meter: 1 | Dejan flasher suddenly stopped working! Help! I've got a problem with Dejan's interface. It worked OK with 3 PC with all phones I had (3210, 5110, 6110, 3310). Some time ago it suddenly refused to work with 3210 v6.00 ID 00898890. Then it stopped to work at all on one of my PCs but worked on the other two ones. Again a little later it stopped to work on all of my three PCs, so I decided to change the chip inside. I've replaced the chip, tested the signal conversion by the debug command and a multimeter and everything was OK, but the flasher produces the same error on all PCs: (Boot count). The diodes and resistors are all checked and found good. So I don't know what was happened and what to do with this. Please, help me, if you can!!! Thanx in advance. Reply, please, to my e-mail as well. WBR, Chris. |
06-02-2001, 14:32 | #2 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | Hi Chris, If I were you,I'll build another interface to isolate the trouble...I think the trouble is still on your interface...unless otherwise, your 3 pc's LPT ports were destroyed by your original flasher. Anyway, it can serve as your backup if all be working normal again.. Regards, neb |
06-02-2001, 16:52 | #3 (permalink) |
Freak Poster Join Date: Apr 2000
Member: 1266 Status: Offline Thanks Meter: 0 | You got virus! You need format all your disk, and re-install operating system! <FONT COLOR="#ffff00" SIZE="1">[ 02 June 2001 17:57: Message edited 1 time, lastly by Supergsm ]</font> |
06-02-2001, 16:59 | #4 (permalink) | |
Junior Member Join Date: Jun 2001
Member: 4829 Status: Offline Thanks Meter: 0 | Quote:
06-03-2001, 01:35 | #5 (permalink) |
Member: 751 Status: Offline Thanks Meter: 19 | Hi Blunty, Why not?!...Especially if your using external power supply on your interface...a defect on your regulator circuit can damage your chip and can inflict it to your LPT port.... As a very good bad examples are, when I damaged my LPT port when I was experimenting with data comm on my hf receiver four years ago.. The next was almost 2 yrs ago, when again damage my com port when I was again experimenting with an M2bus interface.. So...then why you don't believe that a defective interface can inflict problems on your pc ports? Regards, neb |
D500 keypad suddenly stopped working HELP!!! | sarahlou1uk | Samsung Hardware Repair | 2 | 12-23-2007 21:06 |
D500 keypad suddenly stopped working HELP!!! | sarahlou1uk | SWIFT Platform | 3 | 12-23-2007 11:47 |
Dejan flasher suddenly stopped working! Help! | chris_ua | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-05-2001 08:36 |
Dejan flasher stopped working! Help please! | chris_ua | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 06-03-2001 02:40 |
Dejan flasher suddenly stopped working! Help! | chris_ua | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-01-2001 11:33 |
