01-30-2002, 09:30 | #1 (permalink) |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | "Flash Erase Error!" is it a f_loader prob ? |
01-30-2002, 16:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2001 Location: UK
Member: 3430 Status: Offline Thanks Meter: 3 | If you are using Dark flasher (2.14d) then use boot: 956 bytes(default) <br />f loader: intel 16 (from flash id list) this will write to 008988C2. (I have done so today), just remeber after each failed write attempt to disconnect battery from phone before trying again. regards dan |
01-30-2002, 16:35 | #3 (permalink) |
Member: 3430 Status: Offline Thanks Meter: 3 | Some other info that might help is the cpu type setting in dark flasher. My computer being slow means that dark flasher will only work if cpu type normal or slow is selected. ( error from dejan id i select fast). so try and change these speed settings accordingly thanks Dan |
Multi box status " - ", is it dead or? | kraft | Multi-Box | 4 | 08-04-2007 12:15 |
7650 " Erasing Error " | kiran | WD2 & APE (Symbian Phones) | 0 | 09-26-2005 13:44 |
"flash Status Error!" | s4sajii | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-01-2002 12:56 |
"Erase Flash Error!" is it a wrong flash loader ? | s4sajii | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-30-2002 19:19 |
