11-13-2004, 12:51 | #1 (permalink) |
Insane Poster Join Date: Oct 2004 Location: Lagos, Nigeria Age: 51
Member: 84978 Status: Offline Thanks Meter: 1 | help, 3310 "No Access" |
11-13-2004, 14:20 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | try to manual search your phone. if it could locate a network.then if it could locate a network, then try to dial 112 without sim if there is an emrgency call then try to change imei. if it dosen't have an emergency call then replace your p.a.hope this could help |
11-16-2004, 09:18 | #5 (permalink) |
Member: 51453 Status: Offline Thanks Meter: 729 | donnot touch ccont & cobba,check your pa first,coz it is only no access,& i think you can retrieve your network coz you said you have no access,so it means pa is 90% is the problem |
11-17-2004, 22:56 | #6 (permalink) | |
Freak Poster Join Date: Oct 2004 Location: www.doktortelecom.ro Age: 48
Member: 87231 Status: Offline Thanks Meter: 34 | Quote:
2.Verify that the phone sw has MSid 3.change the duplexor(antenna switcht)-it might be broken or 4.change the PA -it might be broken 5 verify if VAPC(Voltage Amplify Power Control) wire is ok in the pcb(it must be connected by a resitor 100 ohm with the HAGAR) 6.change the preamp transistors TX For many questions contact me on yahoo messenger : doktortelecom, | |
Ericsson A2618S "No Access" after charged battery, help PLS! | Ken-mkII | Sony Ericsson Hardware Repair | 7 | 07-21-2004 21:50 |
nokia 3310 "no access" | Shahrukh | Nokia Hardware & Hardware Repair | 2 | 12-19-2003 22:09 |
Ericsson A2618S "No Access" after charged battery, help PLS! | Ken-mkII | Old Ericsson Phones & Sony Phones | 3 | 09-22-2003 13:29 |
3310 "no access" or "found 1 network only" | eureka8888 | Nokia Hardware & Hardware Repair | 3 | 09-16-2002 21:27 |
t20s after repairing - "no access" | Kiryu-ha | Old Ericsson Phones & Sony Phones | 5 | 12-07-2001 09:34 |
